Fitting a Oil Temp Sender ???
Old Jul 9, 2007 | 07:37 PM
AlexD's Avatar
AlexD
Post Miester !
Default Fitting a Oil Temp Sender ???
Can i just drill and tap a hole in this ??
I want to use my SPA Gauge as it only covers boost at the mo.
Al..
Old Jul 9, 2007 | 09:17 PM
DENNIS's Avatar
DENNIS
i think you may run into problems with that ( the temp sender may " bottom out" on the housing or / and cause a blockage ?? )
maybe think about the blank in the pressure sender block ( under the rear of the inlet side of the block )
its not ideal but it would be a good guide.....
Old Jul 9, 2007 | 10:31 PM
AlexD's Avatar
AlexD
Post Miester !
ah kk will have a look at it.
Just dont fancy taking the sump off at the mo.
Old Jul 10, 2007 | 06:03 AM
Another option is to drill and tap the SUMP PLUG and put it there, just means you have to take one wire off each oil change but that's no biggy.
Old Jul 10, 2007 | 07:53 AM
AlexD's Avatar
AlexD
Post Miester !
I had a adapter like that on the saph, worked well, i will have to order the SPA one and see how big it is.
Old Jul 10, 2007 | 10:33 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
If you wanted to do it cheaply - this would be my choice .
Old Jul 10, 2007 | 03:34 PM
AlexD's Avatar
AlexD
Post Miester !
I have called SPA they said they can supply a sender for me to use with
my gauge, but they dont supply a sump plug adapter.
So i know the sender is now a 1/8 NPT i just need to know what the standard sump
plug thread size is ??
Any ideas anyone ???
Ta..
Old Jul 10, 2007 | 03:39 PM
Mike Rainbird
Caraholic
Just buy a TWO new sump plugs* and as Tabs suggests - take it to any engineering shop and ask them to drill and tap it to 1/8 NPT - job done. You will not find an off the shelf adapater as far as I know....
Take the sender though, so they can get the depth right .
*Always have a spare just in case you round of the sump nut getting it off for an oil change.
Old Jul 10, 2007 | 03:43 PM
AlexD's Avatar
AlexD
Post Miester !
I found this :
http://www.demon-tweeks.co.uk/produc...code=GLOFSPM14
From the look of it , it may do the job...
Old Jul 10, 2007 | 03:50 PM
rapidcossie's Avatar
rapidcossie
I drilled an tapped the small block that attaches to the side of the engine block where your oil supply to the turbo comes from.
Standard low pressure warning switch is also there.
I have my SPA oil temp sensor in this block too.
Old Jul 10, 2007 | 03:57 PM
Mike Rainbird
Caraholic
Alex,
I stand corrected - buy it .
Old Jul 10, 2007 | 06:56 PM
Kelv's Avatar
Kelv
Almost there!
Originally Posted by AlexD
I found this :
i got one of those for mine from Rally Design, was no more than about Ł8 - ideal solution if you ask me
Old Jul 11, 2007 | 07:41 AM
dojj's Avatar
dojj
Resident Wrestling Legend
have you seen the size of the spa stuff?
or am i getting mixed up with the temp sender?
mie is in the sump, but the sump has been drilled and tapped for this as i was using the sump plug but the risk of getting the wire snagged was too great
also, the bit you need to unplug isn't at the sender end, it's loads of miles away at the other end of the wire in the gauges that i've got
Old Jul 11, 2007 | 07:51 AM
Mike Rainbird
Caraholic
That's the good thing about the Defi's, you can disconnect the lead a few inches away from the sender .
Old Jul 11, 2007 | 08:44 AM
AlexD's Avatar
AlexD
Post Miester !
Right got on on route
Called Revotec Direct, poxy demon thieves wanted more for delivery
than the fookin plug was worth !!!..
http://www.revotecdirect.co.uk/contact.htm
They are Ł13.87 delivered direct if anyones interested.
Al..
Old Jul 11, 2007 | 09:05 AM
Mike Rainbird
Caraholic
Good find!
Old Jul 12, 2007 | 03:46 PM
dojj's Avatar
dojj
but you still fuck things up if the wire gets snagged and tears things out
manuel boeckx
13
Oct 3, 2015 02:29 PM
Kop2381
Aug 23, 2015 01:17 AM
mrmann
Aug 20, 2015 11:24 PM
marky_g
Aug 19, 2015 11:46 AM
COSWORLD
Aug 14, 2015 07:40 AM
