EFI VS FRST injector sizes
managed to get a FRST EFI motor down here , probably the rarest motor in South Africa
originally set up my Gotech Motor myself with std EFI injectors from an EFI XR3i with the T34 not connected(complete with XR3 EFi head)
ive had a delay getting my RC 500cc injectors and so thought i would use the FRST EFi injectors in the interim while i run the motor in for 1000km before taking it to Gotech for a full setup
problem is ,the std EFi injectors are exactly the same!!!!
picked it up when i swopped them out and did not get overfuelling as i suspected , my a/f meter stayed in the same place and the EGT was not running cooler
is this possible?
are the injectors the same?
EFi ones are blue , FRST are slightly darker(could be due to age?) . but the numbers on the plastic are the same except for perhaps serial or batch numers on the side
anyone got pics of std EFi and and FRST EFi ones
anybody have an idea of sizing
ive read the standard EFi ones are around 170cc?
is this possible?
well really the injectors will prolly max out at around 160bhp...
i have beiges in mine, and mine is running 202bhp but the tuner says he dont want to try improve as the injectors will max out..
Originally Posted by steven botes
WTF
surely 170CC injectors are close to 80% duty cycle at the standard 0.55BAR?
what then is the max boost with these injectors?
Originally Posted by NEWTON
depending on what management you runing
mk3ste
Oct 17, 2021 10:09 AM
Johnny Knoxville
Sep 30, 2015 07:21 AM
