zetec turbo
Old Jul 7, 2007 | 08:25 PM
NEWTON's Avatar
NEWTON
Default zetec turbo
diffrences in silver top and black top,why do people seem to turbo the silver top, thanks
Old Jul 7, 2007 | 08:32 PM
pollocks's Avatar
pollocks
cheap and readily available you can pick a silver top up ready for a strip down for Ł100
Old Jul 7, 2007 | 08:47 PM
NEWTON's Avatar
NEWTON
is that it just because of cost
Old Jul 7, 2007 | 08:51 PM
NEWTON's Avatar
NEWTON
are they basicly the same engine
Old Jul 7, 2007 | 10:37 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
main caps are stronger on the silver top block
Old Jul 7, 2007 | 10:41 PM
Brian's Avatar
Brian
Need a extra pulley added to the black top so the water pump turns the correct way
Brian
Old Jul 8, 2007 | 02:42 AM
NEWTON's Avatar
NEWTON
MD Costhank for the good imfo
Briancheers,looks like ill be going for the silver top then
Old Jul 8, 2007 | 05:08 AM
Just been a VERY good feature in either PF of FF, on this subject, worth a read.
Old Jul 8, 2007 | 06:24 AM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
PF Mag, Its the "Budget Zetec Turbo Guide"
I have a Silver top to turbo
Old Jul 8, 2007 | 07:19 AM
Garage19's Avatar
Garage19
So after spending all that money on the cvh are you coming over to the darkside?
Both the black top and the silver top have different advantages/disadvantages so it is best to use a mix of parts from both.
Old Jul 8, 2007 | 12:11 PM
NEWTON's Avatar
NEWTON
yes,i want to try out the zetec,im building it for another project,thanks for your replys
Old Jul 8, 2007 | 12:15 PM
NEWTON's Avatar
NEWTON
are the valves the same in both engines?? does anyone know
Old Jul 8, 2007 | 12:16 PM
smitsturbo's Avatar
smitsturbo
the blacktop comes with better conrods which are allot lighter than the silver tops in turn revs better...so im told
im just about to turbo an ST170 engine as the head is a lot better than the silver top. plus i got the engine cheep
& fancy seing what it can do
Old Jul 8, 2007 | 12:19 PM
NEWTON's Avatar
NEWTON
it wouldnt matter about the rods,ill be going for steel items and forge pistons,thanks
Old Jul 8, 2007 | 12:20 PM
smitsturbo's Avatar
smitsturbo
so am i
Old Jul 8, 2007 | 12:23 PM
NEWTON's Avatar
NEWTON
so am i
do you know if the valves are the same in the black top to the silver top?
Old Jul 8, 2007 | 04:30 PM
spudmurphy's Avatar
spudmurphy
so am i
I dont think so, I think there is a difference in the number of rings in the valve stems for the collets. IIRC there are 3 grooves in the earlier (silvertop?) valves and only one in the later ones.
However that could all be bollox so I'd wait and see if anyone tells me I'm wrong
Spud
Old Jul 8, 2007 | 04:58 PM
Red16's Avatar
Red16
spudmurphy silvertop valves do have 3 grooves for the collets
Old Jul 8, 2007 | 08:53 PM
NEWTON's Avatar
NEWTON
and black tops dont??????
Old Jul 8, 2007 | 09:22 PM
Brian's Avatar
Brian
I did have a silver top that i was going to to use to build my zetec turbo but then a black top come up cheap so bought that instead
Brian
Old Jul 8, 2007 | 10:56 PM
Red16's Avatar
Red16
just backing up what he said about the silver top rods
with regards to the black top rods...i dont know... thats why i didnt say if they do or not
Old Jul 9, 2007 | 12:12 AM
NEWTON's Avatar
NEWTON
thanks anyway
Old Jul 9, 2007 | 09:49 PM
Red16's Avatar
Red16
no worries
robnock
21
May 13, 2019 05:29 PM
robnock
Aug 22, 2015 10:51 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
