Car keeps cutting out
Old Jul 7, 2007 | 04:27 PM
rstjoe's Avatar
rstjoe
Default Car keeps cutting out
Got a slight problem, my S2 keeps cutting out when i drive along! have tested the fuel pump and the battery is holding charge. i just drive along and it cuts out and will sometimes start and sometimes not!
anyone got any ideas
Old Jul 7, 2007 | 04:30 PM
JimmyBoy's Avatar
JimmyBoy
Would it be an air leak ?
Old Jul 7, 2007 | 04:40 PM
Moonie's Avatar
Moonie
Possibly an electrical problem.
When it cuts out and will not start can you hear the fuel pump?
Old Jul 7, 2007 | 04:41 PM
rstjoe's Avatar
rstjoe
i can drive for a mile or so and then cut out, this morning i drove it 10 miles and then it cut out, it almost seems as something is loose and shorting out? i have no idea!
rstjoe's Avatar
rstjoe
yeah the pump seems ok
Old Jul 7, 2007 | 04:47 PM
Moonie's Avatar
Moonie
Proably a poor conection somewhere.
With the engine running try moving the loom around and wiggling the wiring to sensors etc to try and locate the fault.
Could also be the hall sensor in the dizzy breaking down.
Old Jul 7, 2007 | 05:03 PM
rstjoe's Avatar
rstjoe
cheers for the replys, i have changed the dizzy and rotor arm, but im thinking it has to be a dodgy connection some where!
Old Jul 7, 2007 | 09:33 PM
Rick's Avatar
Rick
When u say it cuts out - how? At what rpm? What load? WHat happens exactly? What does the rev counter do? Does it splutter? Is it a dead cut?
Old Jul 7, 2007 | 09:46 PM
©hatter Box's Avatar
©hatter Box
fuel pump relay have you taken it out to see if its burnt out?
Old Jul 7, 2007 | 09:56 PM
rstjoe's Avatar
rstjoe
I have changed the fuel pump relay, as for the cut out. it splutters and then cluts out its can be through any rev range.
once it has cut out it will sometimes start and sometimes it will. its very stange
Old Jul 7, 2007 | 10:19 PM
Rick's Avatar
Rick
So you could be on boost, and suddenly it will splutter?
Old Jul 7, 2007 | 10:33 PM
rstjoe's Avatar
rstjoe
i dont have to be on boost i can be driving off boost and it will happen!
Old Jul 7, 2007 | 10:34 PM
©hatter Box
3 wires in the dizzy must be a break in wires to the fuel pump?
Old Jul 7, 2007 | 11:24 PM
Rick's Avatar
Rick
rstjoe
Yes, but does it do it ON boost? And is a dead/clean cut - or splutter?
Old Jul 8, 2007 | 01:10 PM
Micky's Avatar
Micky
Change the coil.Regards,Micky
Old Jul 8, 2007 | 07:04 PM
Lincolndanny's Avatar
Lincolndanny
as Mikey says, change your coil, had this on mine
Old Jul 9, 2007 | 08:27 PM
steven botes's Avatar
steven botes
check and replace your battery earth wires if necessary
remove and clean/tighten where they fasten to the body/gearbox
bad earths are the most common electrical problems you can have , especially with the amounts of rust your cars have your side , i want to cry when i see it on your project cars......
Old Jul 9, 2007 | 11:07 PM
SafeChav's Avatar
SafeChav
Dizzy would be my favourite, i dont think theres an RS left that hasn't suffered with the sensor breakinf down (mine is on its way out).
Next time it happens watch the rev counter.........
And if it wont restart listen for the fuel pump when trying to restart, you'll probably find it will only prime and doesnt run when you crank the engine.
Old Jul 11, 2007 | 06:53 PM
drsrst2zvh's Avatar
drsrst2zvh
Had exactly the same problem on mine when i used to be sat in traffic it would just cut out , the loom by the fuse box that runs along the bulk head used to get hot and there was obviously a broken wire in there. wiggled it about and would start again. ended up havin to change the wiring loom got one for £40 with a clifford concept 500 on it!!!!!
Fordmad!
Sep 26, 2015 05:24 PM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
john_3.0s
Aug 15, 2015 07:44 AM
track.focus'd
Aug 12, 2015 05:53 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
