what mean cossie touring-car spec head
Old Jul 5, 2007 | 06:15 PM
sygjim's Avatar
sygjim
Default what mean cossie touring-car spec head
i has seen this :
touring-car spec head ..........
somebody can explain the work to do, to have this ...
Old Jul 5, 2007 | 06:37 PM
JonnyBravo's Avatar
JonnyBravo
Link ?
Definately going to need more info if you want anyone to give you some answers
Old Jul 5, 2007 | 06:38 PM
sygjim's Avatar
sygjim
or just want to knwo the spec of this head
Old Jul 5, 2007 | 07:24 PM
Deano's Avatar
Deano
Doesnt it relate to the size of the ports when people claim " Touring Car spec head "
Ie 27mm Inlet ports and 26mm exhaust ports
Old Jul 5, 2007 | 07:27 PM
JonnyBravo's Avatar
JonnyBravo
Sorry mate, misread your post.
Old Jul 5, 2007 | 07:41 PM
sygjim's Avatar
sygjim
i had received the last performance ford magazine, and a sierra is shown, and they had that the car has a TOURING CAR SPEC HEAD ....
so, i am interesting to know what it s mean
Old Jul 5, 2007 | 07:47 PM
JonnyBravo's Avatar
JonnyBravo
At a guess Tony @ Turbosystems could answer that although I have no idea what his username is since the name changes.
Probably quite a lot of pretend touring car spec heads about but if you want the real thing then you will need to get some large amounts of money out.
At a guess I'd think it is around Ł2000 for a proper cylinder head
Old Jul 6, 2007 | 04:00 PM
sygjim's Avatar
sygjim
nobody else
Old Jul 6, 2007 | 04:06 PM
Jim Green's Avatar
Jim Green
Jonny Bravo : 2k....LOL, and the rest.
When I had Karl (NMS) build my fully ported head for my new engine, that was nearly two and a half grand.....New Everything, on a virgin head, but that didn't include the price of the head.
So if you went to someone like Mountune and asked them for a Genuine Group A Cylinder head, I would hate to think what price they'd come back with !!!!
And when you say Group A Cylinder Head.....I'm assuming you mean including the valves. Which alone are around sixty pounds each for the sodium filled exhasts.
I'm also sure there's a few heads around that are quoted as being "Group A Heads" but which probably are not.
There were so many engine builders producing the engines when the cosworth was doing the BTCC, that there's bound to be differences between what one builder refers too as a Group A Head, and what another builder would consider the same.
Old Jul 6, 2007 | 06:28 PM
JonnyBravo's Avatar
JonnyBravo
Upto 2k for the work mate, not the mechanical parts
I have seen some of Nik Waples work as my x was his daughters best friend and I know you pay a lot for quality
Old Jul 6, 2007 | 06:32 PM
Jim Green's Avatar
Jim Green
Yep....that's probably the price for a correctly ported head by someone like Nik, Karl, Mountune etc.
But then you need the valves, springs, followers.....and of course a damned good head to start off with, as you wouldn't want to spend that sort of money, using a head that was on it's final skim
I'm thinking around 3k - 3.5k for an off the shelf Group A Head. (All fully built up, and complete with valves, springs, followers etc and ready to fit.)
Old Jul 6, 2007 | 06:34 PM
Lee_R21Turbo's Avatar
Lee_R21Turbo
Are standard cosworth exhaust valves not sodium filled then??
Old Jul 6, 2007 | 06:47 PM
Jim Green's Avatar
Jim Green
Standard Valves, Yes, but from what I remember it's only the exhaust valves that are sodium filled...........not the inlets.
Feel free to correct me if I'm wrong, but I believe that's the case.
Old Jul 6, 2007 | 07:01 PM
NEEDFORSPEED's Avatar
NEEDFORSPEED
mine was 2k without cams etc but all machining on chambers/ports, mods for valve springs etc and a few more helicoils than id like lol proper heads cost big doh
Old Jul 6, 2007 | 07:05 PM
NEEDFORSPEED
although saying this these cnc heads seem to be takeing off, so i guess a big spec head (without changing valve size) will cost alot less not doing it by hand?
Old Jul 6, 2007 | 07:12 PM
JonnyBravo's Avatar
JonnyBravo
Didn't Euan have a cnc head ? they still need finishing iirc
Must save a serious amount of work though
Old Jul 6, 2007 | 07:15 PM
Jim Green's Avatar
Jim Green
It's the way a "head".....
Old Jul 6, 2007 | 08:30 PM
radiant red's Avatar
radiant red
Thing is sodiun filled valves are not needed on road engines right??
Surely EVERY turbo car would have them??
Old Jul 6, 2007 | 09:18 PM
Lee_R21Turbo
Well Renault 21 Turbo engines have them as standard...the exhaust valves anyway!!!! I'd imagine its a wise decision really considering the heat that they are exposed to on boost!!!
Old Jul 7, 2007 | 12:11 AM
NEEDFORSPEED
my dads split screen camper van with 911 engine on twin 45's had sodium filled valves lol!!
Old Jul 7, 2007 | 06:05 AM
Jim Green's Avatar
Jim Green
They are standard in the cosworth engine... (Exhaust Valves). Inlet valves are not sodium filled as standard though.
Old Jul 7, 2007 | 07:23 AM
Lee_R21Turbo
I know they do.....I'm not disputing that!!! LOL! I was replying to Radiant Reds post about road cars not needing them and was merely using the 21T as an example!!!!
Old Jul 7, 2007 | 07:34 AM
simonc's Avatar
simonc
Just looked on the engine invoice for my sapphire which has a Grp A cylinder head fitted but was secondhand from a touring car, it was built by Graham Goode Racing & was Ł1500 supplied secondhand & that was 9 yrs ago when it was built,total engine build was Ł11k including remove/refit & breather kit & other pipes etc but still going strong 9 yrs later. Previous owner paid, not me
Simon.
Old Jul 7, 2007 | 07:50 AM
Jim Green's Avatar
Jim Green
Simon C : So by Graham Goode's prices, that would be about 6k now....
Old Jul 7, 2007 | 08:08 AM
Fiecos Dan's Avatar
Fiecos Dan
my touring car head was less than 2k. for work,build and cam's.
all matters who you know. and how much they charge.
jessie_rs
62
Aug 6, 2019 09:27 PM
Kam B
Sep 24, 2015 10:40 AM
kevin36
Sep 8, 2015 12:23 PM
hopper350
Sep 4, 2015 12:53 AM
