Oil Cooler - Mounting
Old Jul 3, 2007 | 11:37 PM
dave_y's Avatar
dave_y
Default Oil Cooler - Mounting
where have people mounted their oil coolers?
was going to fit mine behind the front bumper vent (90 spec) on the drivers side but the hoses dont reach
Old Jul 3, 2007 | 11:43 PM
Micky's Avatar
Micky
Get longer hose's then!!!!!!No point in mounting the cooler in a crap wind flow free place now,is there???Regards,Micky
Old Jul 3, 2007 | 11:56 PM
dave_y's Avatar
dave_y
can you buy extensions?
got braided hose and its about 2-3 inches too short
agree with you micky, didn't want to mount it inside the engine bay cause
a) its very hot
b) not much room left - no airflow!
Old Jul 4, 2007 | 12:15 AM
mark-rst's Avatar
mark-rst
Mine is mounted where you are saying
got the pipes made to length and run them down the chassis rail then thorugh the hole in the rail
Old Jul 4, 2007 | 12:30 AM
dave_y's Avatar
dave_y
old picture but all i could find...
black line is where cooler is going to be mounted, hoses fit throught the hole shown by yellow arrow and go up passed timing belts round the back to the oil filter but they are abotu 2-3 inches too short..
where do your hoses go down the chasis rails??
Old Jul 4, 2007 | 12:38 AM
Micky's Avatar
Micky
I would measure up the lenght you need and get some hose custom made.Look up the yellow pages for some one near.I like the position you have choosen for the oil cooler.Regards,Micky
Old Jul 4, 2007 | 12:52 AM
mark-rst's Avatar
mark-rst
That where mine is...
I will try and do some pictures for you...
The pipes go through the hole you point at run along the rail then up to the sandwich plate...
My cooler is on opposite diagonal to the way you show though...
like Micky said... measure up and get some made properly... mine cost me 40 quid if i remember right.
Old Jul 6, 2007 | 02:19 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Dave;
This would be a better way of mounting the cooler. You can make the hoses as long as you want.
Old Jul 6, 2007 | 06:19 PM
Fiecos Dan's Avatar
Fiecos Dan
Not ideal, but works fine.
was seeing 125oC+ in 10-15 mins on the track before fitment, now dont go higher than 110oC in 20mins in 28oC ambients.
16 row mocal oil cooler.
Old Jul 9, 2007 | 07:11 PM
steven botes's Avatar
steven botes
use to have mine mine below the fmic
removed the heater intake box and made up a bracket , this is where it now sits.
it does not add to engine temps and oil runs well below 80'c , even at the strip.
i use a 7 row cooler from a Mazda rotary , about half a meter wide
mail me at stevenb@denorco.com , i have some pics on my work pc
Old Jul 10, 2007 | 12:36 PM
dave_y's Avatar
dave_y
Originally Posted by Tony Turbo
Dave;
without sounding rude.. can i ask why it would be better mounted the other way...?
my logic was that the air would come through the vent in the bumper and hit the largest surface rather than being hidden behind the bumper itself.
Old Jul 10, 2007 | 04:51 PM
Tony Turbo's Avatar
Tony Turbo
Good question
Because with it your way, the air would come through the bumper and would be forced over the oil cooler. With it the other way, the angle of the cooler acts as a barrier and because the air cannot go backwards it forces the air through it rather than over.
If you look at all half decent intercooler installs you will see that it isn't totally upright, the top will always be in front of the the bottom, if you look at it from the side. If that makes sense.
Old Jul 25, 2007 | 12:07 AM
dave_y's Avatar
dave_y
155lee
Oct 27, 2015 04:55 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Chopshop85
Sep 18, 2015 06:13 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
StephTell
Sep 2, 2015 06:31 PM
