Oil gauge shows no pressure & overheating issues!
Old Jul 3, 2007 | 04:58 PM
Dumpy's Avatar
Dumpy
Default Oil gauge shows no pressure & overheating issues!
Afternoon,
Having trouble with the RS S2. Cant drive the car on the road yet due to various reasons - basically within the next month or so i need it to be running as sweet as a nut!
Here is my dilemma - i leave my car to stand for about half an hour - go inside the car check the oil pressure, the gauge reads nothing, needle on the low - should the guage show something as i have been told that unless the car is moving the guage wont move (i think this is wrong however) - any help on this?? How do i test the guage - apart from buying a new one!
Overheating issues - cant remember what you guys said about getting a cossy fan sender and 82deg thermostat - any help on where to getthis from??
Last thing did they make a haynes manual for the RS turbo S2?
Any help greatly appreciated
Dumpy
Old Jul 3, 2007 | 07:45 PM
Rick's Avatar
Rick
What gauge, where is it plumbed in?
Old Jul 3, 2007 | 10:14 PM
nellrodd's Avatar
nellrodd
Yes for the haynes manual mate, the number of the book is 0686 which includes the RS turbo.
Neil
Old Jul 4, 2007 | 06:27 AM
Dumpy's Avatar
Dumpy
Cheers Neil.
Its a nimrod gauge - being inexperienced on this - not sure where its connected to, i think the sump plug.
Where else could it be connected to??
Cheers,
Dumpy
P.S any one tell me if it is a cossy fan sender and 82deg fan sender i need, and where can i get them from?
Old Jul 4, 2007 | 06:31 AM
dave green's Avatar
dave green
If the engine gets very hot it will give low oil pressure, as long as the oil level rises nicely when you rev it ,it should not be a problem.
try changing the oil and filtet with a good quality ol and see if that helps
Dave
Old Jul 4, 2007 | 07:21 AM
Aaroncast's Avatar
Aaroncast
http://cgi.ebay.co.uk/ws/eBayISAPI.d...6680&rd=1&rd=1
tese are good -copy and paste into browser
Old Jul 4, 2007 | 09:04 AM
nellrodd's Avatar
nellrodd
When you say you leave the car for a half hour, i take it you mean the car is still running?? The pressure on my gauge does go low when hot and at idle, but not to 0 psi.
Old Jul 4, 2007 | 11:33 AM
Dumpy's Avatar
Dumpy
Yep car is left running for half an hour easily - rev it for a minute or so , no move on the guage!
First thing to do - I'll give it a good old service - would you say 15w40 is a good grade?
I'll get castrol magnetex in there if available!
Cheers for the CD link, will be purchasing!
Anty chance one of you could tell me where to get the sender and thermostat? (if it is the cosy fan sender and 82deg thermostat i need)
Cheers,
Dumpy
Old Jul 4, 2007 | 02:00 PM
antony215's Avatar
antony215
Escort Rs Turbo
If thats where it is then thats why you have no oil pressure on the gauge it needs to be taken from where the standard oil pressure switch is on the back of the engine.
Old Jul 4, 2007 | 02:08 PM
dave_y's Avatar
dave_y
take the turbo oil feed off from the oil pressure switch and use an adadptor to fit in between the two hoses.
Old Jul 9, 2007 | 07:26 PM
steven botes's Avatar
steven botes
try the following , manuals for free!!!!
http://www.siipicossu.com/manuaaleja/manuaalit.htm
gchristophi
Aug 31, 2015 10:36 PM
YODI
Aug 30, 2015 01:12 PM
Adam-M
Aug 26, 2015 05:53 PM
mrmann
Aug 20, 2015 11:24 PM
Bailes1992
Aug 16, 2015 07:14 PM
