ignition fault
hi all,
sometimes when i turn the key i have no ignition lights, the fuel pump
doesnt run and when i turn it all the way it doesnt turn over either,
this only happens every now and then. if you keep turning the ignition
on and off it eventually decides to work.
i have replaced the ignition barrel and i have double checked all the wires
to make sure they are all secure.
i cannot find anything obvious and have checked just about everywhere
for loose wires etc.
any ideas?
any ideas?
Daniel Howard
17
Sep 26, 2015 12:39 AM
