i want to go faster
Old Jun 28, 2007 | 10:04 PM
Tonyt1t's Avatar
Tonyt1t
Grey Mk4 Early XR3I
Default i want to go faster
ok guys im on a small budget but i want my car to have more power
can any one recomend a few things that will improve power and performance without breaking the bank?
been thinking along the lines of kent cams ect would i be going in the right direction?
Old Jun 29, 2007 | 07:16 AM
I would do exhaust and air filter first, as these will be needed anyway, then cam.
Old Jun 29, 2007 | 12:10 PM
Tonyt1t's Avatar
Tonyt1t
Grey Mk4 Early XR3I
ive been told i cant upgrade the air filter as its the way the engine runs or somthing and will screw the seettings up? its an MFI 105 bhp thingywould a differnt panel filter make much differnce?
Old Jun 29, 2007 | 12:43 PM
You were told a load of crap then!!
MFI stick a panel filter in.
Any car will benefit from better breathing, I had a K&N panel in my 4i, was a bit better midrange.
The system is very crude, well crap to be honest these days, but will not later the fuelling(AFR) at all, air speed causes depression which moves plate down allowing more fuel end of>
Old Jun 29, 2007 | 03:18 PM
Tonyt1t's Avatar
Tonyt1t
Grey Mk4 Early XR3I
ideal so k n n panel filter in followed by a full oil change sump gasket change oil filter change fuel filter change then start upgrading cams exhaust ect?
Old Jun 29, 2007 | 03:38 PM
I would do exhaust first, before cam.
I know when my dad used a Janspeed on his xr3(1980) it worked really well.
Old Jul 24, 2007 | 11:49 PM
jawanne's Avatar
jawanne
hi i had a mk 4 mfi the only way u can put a induction on is if you can get a a old volvo 2later the fuel metering is similar to an escort mfi. the case of the volvo metering unit under neath has a pipe outlet and it bolts straight on where the escort mfi one goes and its sounds really nice.4 branch manfold can out let more power but i think its better and cheaper just to put a 18 zetec in...hope that helps
Old Sep 13, 2007 | 10:50 PM
escort_cosworth_monte_163's Avatar
the cheapest way too boost a xr3i mfi is a 25bhp nitro jet try and get 25 bhp any other way for 400 quid
landaqmabba
Sep 15, 2015 07:16 PM
JC
Nov 19, 2004 10:39 AM
Porkie
38
Nov 1, 2004 07:45 PM
Rene
156
Oct 12, 2004 03:28 PM
R4N SS
Aug 14, 2004 09:06 PM
