exhaust wrap
could anyone tell me if this is worth getting for my cossie downpipe
want to heat wrap it so i dont melt any wiring etc and burn my paint
http://cgi.ebay.co.uk/EXHAUST-HEAT-W...QQcmdZViewItem
http://cgi.ebay.co.uk/Exhaust-Wrap-K...QQcmdZViewItem
thanks
thanks
you might aswell....if you think its going to melt some wires etc...
it looks good aswell..
i wrapped my 4branch and some of the exhaust and it took the underbonnet temp down a treat!
I've bought some of that stuff off that ebayer, only thing I will say is that it goes very brittle once its got warm, not sure if all wraps go like that!!!! Make sure its tied well afterwards as if you go to touch/remove the downpipe it crumbles off!!!
The cheap stuff is more likely to fall to bits tbh.
I used Thermo Tec wrap to do the manifold on a car.
http://cgi.ebay.co.uk/Performance-Ex...QQcmdZViewItem
Much more pricey but my mate uses it on his 800hp corvette and so far its not fallen to pieces like others I have seen.
If you look under exhaust wrap on ebay you will also find the metal ties which work very well.
When fitting it you need to make it nice and damp (I soaked it) then apply it nice and tight.
Warning though, it will feel like you have just slept with a community of fleas if you dont wear some sort of gloves
i should be alright then
as i only need to cover just down to where it goes to chassis leg
im running a heat sheild aswell just want to ake sure i dont melt anything this time
i will get teh pack of ties
tbh the one i want is the one you have to wet
as this does set quite solid ive seen
metal ties i will get aswell
just dont know how much im going to need
as if i dont need to spend 50 quid i wont, i want to get my moneys worth
i know but im going to be pissed if i buy that and only use 1/4 of it
and the fuker with teh postage costs
so to wrap my downpipe up im going to be looking near on £65
Hi
the only way you will get any heatwrap to last is by spraying it with hi temp silicon coating, otherwise it will just crumble when touched. If you spray the wrap it feels like a plaster cast.
15foot 2"wide does about 8" or 9" of 3inch pipe.
I've been told you be a little bit careful as some of the heatwraps have asbestos in it - not sure if its true
and we sell all of the above DEI products, Pm me if you want any prices etc.
HTH
HTH
Originally Posted by Dan@Rapid-Ford
Hi
HTH
HTH
I've wrapped my exhaust from turbo to tail pipe
