Major Service Advice
Ive just recently bought a 1986 3 door with 57k on it. I want to do a major service on it, what all is advisable to do?
Oil + Filter
Timing belt
Cam seals as they are leaking a tiny bit.
Head Gasket
Fuel Filter
Plugs
Distributor
Anything else anymore can suggest doing?
Thanks
Oil + Filter
Timing belt
Head Gasket
Fuel Filter
Plugs
Distributor
Thanks
air filter if its a k&n type clean & oil it
check alternator belt
top up water, check anti freeze concentration
check brakes discs / pads for wear
suspension linkages, ball joints, gaiters etc
exhaust
ht leads
thats what i can think of on top of what you have already said.
exhaust
ht leads
Tensioner when you do the belt.
Check carefully the PHASE sesnor wires inside the dizzy as early ones fall to pieces.
If doing the cam seals might as well use VITON seals as way better than ford ones.
rsguy
44
29-09-2015 03:29 PM
