Turbo oil feed part
Old Jun 25, 2007 | 12:23 PM
nellrodd's Avatar
nellrodd
Default Turbo oil feed part
Hi all,
Can anyone tell me what the part where the oil feed pipe screws onto on the turbo, the "adapter plate" bit that bolts to the turbo (sorry for the descritpion) and where i can get another one from. Mine has the the feed hose welded to the plate, and i have a new feed pipe to put on. Its for T3 off a S2.
Many thanks.
Neil
__________________
Old Jun 25, 2007 | 06:06 PM
Fiecos Dan's Avatar
Fiecos Dan
They usually screw into the turbo direct.
so remove the plate thats bolted, and get a 1/8 - 1/4 male to male union.
and then you can screw that into the turbo, and oil feed line onto that.
Same as this, but i have a pre turbo oil filter fitted.
Old Jun 25, 2007 | 10:46 PM
nellrodd's Avatar
nellrodd
Hi mate, i see what you mean, but not sure its what i need. I have the same part that needs to be un bolted from the turbo, but where yours has the threaded union on top of the plate, mine hasnt and the oil feed pipe has been welded to the plate. So i need a replacement plate, so i can screw my new oil feed pipe to it. So can you buy these plates, and and what are they called??
Cheers,
Neil
Old Jun 26, 2007 | 05:03 AM
Fiecos Dan's Avatar
Fiecos Dan
Not fone like that as std, sounds like a bodge of sorts.
that plate could be made with ease. but worth converting it back to std, as easier and cheaper.
get a pic of yours up?
Old Jun 28, 2007 | 02:17 PM
nellrodd's Avatar
nellrodd
Okay here's a pic of what im on about, as you can see the oil feed pipe has been welded on, so i need a new plate with the threaded connection to attach my need feed pipe.
[/img]
Old Jun 28, 2007 | 06:06 PM
Fiecos Dan's Avatar
Fiecos Dan
Or just remove plate,
and fit a Std union into the threads that under the plate.
Old Jun 28, 2007 | 09:37 PM
nellrodd's Avatar
nellrodd
Yeah i know mate, thats what i want to do is to replace that part, but i dont know what its called nor where to get it from, any help?
Neil
Old Jun 28, 2007 | 10:10 PM
Fiecos Dan's Avatar
Fiecos Dan
You need a 1/8 to 1/4 double male union.
then that will screw into your turbo, and a Std rst oil feed line will screw onto that.
Try a hydrolic hoses/fitting store. about £3.
i have them spare. if you pay for it, and the postage.
Old Jun 29, 2007 | 10:39 PM
nellrodd's Avatar
nellrodd
Hi mate, well if what you have will cure my problem and allow me to get me new feed hose on, then let me know what you want for it please.
Neil
Old Jul 1, 2007 | 08:38 PM
Fiecos Dan's Avatar
Fiecos Dan
i have a used, but like new union, call it £5 all inc.
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
Oct 9, 2015 07:38 PM
Matt Baxter
Sep 16, 2015 08:30 PM
Bailes1992
Aug 16, 2015 07:14 PM
muz
Aug 16, 2015 12:57 PM
