are st170 inlet ports the same as blacktop zetecs?
Old Jun 22, 2007 | 06:31 PM
smitsturbo's Avatar
smitsturbo
Default are st170 inlet ports the same as blacktop zetecs?
as above realy thanks in advance
Old Jun 22, 2007 | 06:37 PM
XRT_si's Avatar
XRT_si
No from what i understand they are a LONG way off. ST170 heads flow to 400bhp with standard valves just need the VVT remeoved and exhaust ports opened up a little. well thats what Ian Howell told me last week
Old Jun 22, 2007 | 06:39 PM
smitsturbo's Avatar
smitsturbo
are the stud patterns the same tho?
Old Jun 22, 2007 | 11:03 PM
st3v3's Avatar
st3v3
i dont think they are, but i might be wrong as ive had a few beers
Old Jun 23, 2007 | 08:58 AM
AustenW's Avatar
AustenW
same stud pattern, alot bigger port shape
Old Jun 23, 2007 | 09:15 AM
Ginge !'s Avatar
Ginge !
just finding my feet
WHY would you remove VVT
its one of the BEST engine advances about,,,, different cam timing to keep valves open longer and allow MORE airflow and then lower the ca timing for better lag free driving round town meaning no need to change to 2nd to get round town
why would anyone remove it,,,,, unless they dont understand how to use it
but like taking a 16v engine out and fitting a 8v engine,,,, why go backwards
whats the cam duration and lift like at high rpm,, considering the vvt reduced the lift and duration lower rpm,,, thus lowering the air flow on a good flowing head
Old Jun 23, 2007 | 09:17 AM
Ginge !'s Avatar
Ginge !
for his next trick he will remove electricity from hes house and fit candle
remove central heating and fit a wood burning fire in each room
jessie_rs
62
Aug 6, 2019 09:27 PM
timsrs
22
Sep 24, 2015 08:14 PM
Andypandy260
Sep 23, 2015 10:28 PM
dombanks
Sep 21, 2015 08:38 PM
Chopshop85
Sep 12, 2015 06:42 PM
