Car pulling/wandering to the left
Old Jun 20, 2007 | 06:17 PM
Lee1972's Avatar
Lee1972
Formerly COSSIE_LEE
Default Car pulling/wandering to the left
My Escos under normal driving seems to be wandering slightly to the left when you let go of the steering wheel. When you hold the wheel it seems as though it wants to slightly force its self to the left. Under heavy breaking it seems to get a lot worse and pulls to the left a lot quicker! Ive already changed the front breaks and pads and also replaced the front bushes.
Tracking had been checked, all OK
It only last week had a service and MOT and the garage didnt find anything.
Anyone have any other ideas what it could be?
Cheers,
Lee
Old Jun 20, 2007 | 07:25 PM
ECOS95's Avatar
ECOS95
Have you had the front geometry checked ? Mine was the same & is much better after it was adjusted to 0.5mm toe in on each side I'm sure it was.
Made a big difference.
Old Jun 21, 2007 | 12:42 AM
Lee1972's Avatar
Lee1972
Formerly COSSIE_LEE
Though they did toe with tracking?
Did it cure your problem? My car didnt do it for 4 and a half years and six months ago it decides to play up
Old Jun 21, 2007 | 12:01 PM
ECOS95's Avatar
ECOS95
I'm sure the garages set them to run 0mm toe in or out. Its worth a try as it only cost me Ł15 at a place that did laser alignment.
Old Jun 21, 2007 | 06:05 PM
Lee1972's Avatar
Lee1972
Formerly COSSIE_LEE
Ive just had it all aligned, not sure that will cure it?
Does anyone else have any ideas?
Old Jun 24, 2007 | 08:17 PM
Lee1972's Avatar
Lee1972
Formerly COSSIE_LEE
With all these cossie experts in here aint no one got any other ideas?
Old Jun 25, 2007 | 02:37 PM
auralisRS's Avatar
auralisRS
Road camber....most cars do it I've driven, the roads is built with that angle on it to allow the rain to run off....
Drive the car in th middle of the road, so white line goes under centre of car and try. Make sure there ain't no large trucks coming.
Old Jun 25, 2007 | 02:44 PM
- Sim -'s Avatar
- Sim -
a rubber broken? from the damper or from the sway bar?
everything is fix? no loosen screws? a damper leaking?
Old Jun 25, 2007 | 07:46 PM
Lee1972's Avatar
Lee1972
Formerly COSSIE_LEE
Doubt its to do with that as it only started to do it 6 months ago, before it would drive straight plus when breaking from high speeds it pulls quite badly to the left, so much that it has to be corrected by turning the steering wheel to the right.
Old Jun 26, 2007 | 01:56 PM
cossieDavedree's Avatar
cossieDavedree
U say u got a laser alignment,,, Did it show the rear wheels as being out at all?? bent rear , very easy to do as they are so weak,
whats the mileage of the car. Any tyre wear on edges, have the cords of the tyres twisted? Happend on my van. New tyre and it drve straight again.
Play in steering rack? Broken damper spring's weak damper spring's,
Tracking not done properly ??
Old Jun 26, 2007 | 01:58 PM
cossieDavedree
did it start pulling after the mot ?? did they drive it or where you there all the time the car was there
Old Jun 28, 2007 | 07:23 PM
Lee1972's Avatar
Lee1972
Formerly COSSIE_LEE
Thanks for the reply cossieDavedree, it started wandering before the MOT, when I got the alignment done nothing needed adjusting, all wheels were correct. It done 53,000. All tyres are fine, not showing any worse wear on any tyre. Think i`ll get the steering and springs checked next then.
cheers
Lee
j.hammond1
30
Oct 31, 2021 05:28 PM
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
Adam-M
22
Aug 10, 2015 10:46 AM
tankybaby66
Aug 9, 2015 07:13 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
