big turbo lag-ignition timing?
I see that few members have problems with turbo lag, turbo kicks hard at 4000 rpm, not before. On mz rst boost start rising on about 2000+ rpm but hard kick comming at 4000 rpm. I think it is too late.
Is possible that problem is in ignition timing?
because I am sure that my mechanics dont remove map hose and dont set rpm to about 850, when setting ignition, and few people told me if set ignition like he, ignition can be too retard. if u understand my english
engine is standard. dont have dump valve. Boost is 0.5 bar (about 7 psi i think). and car goes well but pull hard at 4000 rpm. everything is ok (wastegate is ok, hoses are ok, turbo ok)
Just one question, I put here one picture (dont laugh this is only ilustration), I dont know which "toth" is correct, on place X, because here is few toths. thanks
yes, actuator spacer. I try to refit this piece but looks bad, when I put it under any of two screws, actuator rod going too far from turbo " moving metal piece" (dont know name).
Fiecos dan: you mean that I shorten rod for 8 mm? I dont know what is preload :/
thanks mate
thanks mate
Preload is the amount the actuator arm is pulled to fit on to the wastegate.
usually preload is 4-6mm, but can be as much as 12mm, as long as the wastegate can still be opened 5-6mm when actuator is fitted.
damn...i dont understand this...
you mean, I can try to rotating one part of actuator arm and shortened it? and have more boost?
sorry Dan for being boring
p.s. when I pulling actuator arm on wastegate, wastegate is fully open (fully right)
you mean, I can try to rotating one part of actuator arm and shortened it? and have more boost?sorry Dan for being boring
Yes, its adjustable,
with a 11mm spanner, undo lock nut, then turn to shorten or extened.
(shorten will give more boost, roughly 2 turns will see 0.5 psi )
looking from underneath, if the wastegate is fully anti clockwise, this is fully shut.
a std actuator if in good condition can be set to 15+ psi with either a bleed tap, or another boost controller.
i'm not telling you to up the boost, but Test where it comes in.
Cameron
14
Aug 9, 2015 06:28 AM
Escortdriver1
Jul 31, 2015 02:36 PM
ok. is normal that "biggest kick" comming at 4000 ? I feel that turbo pulling car at 3000 but at 4000 pulling is hardest. maube T3 is guilty for that?
