rear trailing arms
Old Jun 18, 2007 | 08:36 AM
StephenC's Avatar
StephenC
..BS Motorsport..
Default rear trailing arms
What options are there for replacing these? Standard or modified and who from?
Old Jun 18, 2007 | 08:40 AM
Aaroncast's Avatar
Aaroncast
on a what??????????-box and bush if rs-ser 1/2
Old Jun 18, 2007 | 08:52 AM
StephenC's Avatar
StephenC
..BS Motorsport..
series 2
Old Jun 19, 2007 | 09:25 PM
Rick's Avatar
Rick
I can do you some brand new adjustable's for Ł60. Allows you to adjust the rear toe, which makes a huge difference to handling.
Old Jun 19, 2007 | 09:42 PM
StephenC's Avatar
StephenC
..BS Motorsport..
not fussed on adjustable been honest but that price seems pretty good mate, could you pm me more details (pics?) on getting them off you mate
thanks
Old Jun 20, 2007 | 08:56 AM
user 7082039239's Avatar
user 7082039239
Don't mention ze Vor
I was thinking about that lately. I guess you could make it a lot more tail-happy by giving it a bit of toe-out. Can you show me, where you can make toe adjustments on these? Picture would be great!
Wouldn't adding an additional washer to the bush where the tie bar meets the rear tca have a similar effect?
Here's a (quite exaggerated) drawing:
Old Jun 20, 2007 | 09:09 AM
NUTS RuS's Avatar
NUTS RuS
Its usually useless if you have rubber bushes Peter.
Im thinking Rick means he can adjust castor not toe
Old Jun 20, 2007 | 11:31 AM
user 7082039239
Isn't caster only an issue on the front where the steering is?
Old Jun 21, 2007 | 06:38 AM
JesseT's Avatar
JesseT
There are a varying number of washers already from the factory setting different toe for different models.
Old Jun 21, 2007 | 06:46 AM
user 7082039239
Now that's really interesting. How many are there usually on an RST?
Old Jun 21, 2007 | 07:01 AM
NUTS RuS's Avatar
NUTS RuS
Pulling or pushing from the centre of the hub is NOT the correct way to set toe. They were for differing ride heights were they not ? Allowing them to use the same length arm across all models.
Old Jun 21, 2007 | 03:14 PM
JesseT's Avatar
JesseT
I think there were two small ones before the huge concave one.
Old Jun 21, 2007 | 05:38 PM
Aaroncast's Avatar
Aaroncast
during hard stage events they can bend-trick is to weld 4+25 mm bar along its length on both sides(one arm) x2 and box out the top to stop gravel getting in and it adds strength also-but i suspect your not staging it?? but if you DID!!!!!!!!!!!!!!!!!!!!!!-
Old Jun 21, 2007 | 06:09 PM
StephenC's Avatar
StephenC
..BS Motorsport..
I just want to replace them and ford cant help me out
Old Jun 21, 2007 | 06:24 PM
NUTS RuS's Avatar
NUTS RuS
I have a box full of unused ones in my mates shed I think.
Thought I binned them ages ago but apparently he found them lurking in his shed. God knows what else is in there then
155lee
Oct 27, 2015 04:55 AM
Fudgey
Sep 17, 2015 01:06 PM
Tony W
Sep 9, 2015 12:08 PM
rsturbo27
Sep 5, 2015 05:08 PM
