Changed Head Gasket - Still Boiling Over - EDIT NOW FIXED
Old Jun 14, 2007 | 09:45 PM
PeterLucas's Avatar
PeterLucas
Default Changed Head Gasket - Still Boiling Over - EDIT NOW FIXED
Following on from previous post.....
(4x4 Cossie Engine)
Car was badly boiling over, so whipped the head off..... No signs of cracked block, damaged head, or failed head gasket. Changed head gasket and removed thermostat. Filled car with water, run engine and bled at thermostat point. Fans cut in and I thought prob solved, but the engine continued to get hotter and the fans kept cutting in latter and latter each time. The whole time the system was pressuring more and more and the expansion tank boiled its contents again
Ive been given a few ideas tomorrow but could really appreciate any help on this, and has anyone come across this before?
Old Jun 14, 2007 | 09:49 PM
The Youth.'s Avatar
The Youth.
air lock.......
and also on a 4x4 you must always run with a thermostat fitted it directs flow even when closed. unlike the 2wd which is a far more basic setup
steve
Old Jun 14, 2007 | 09:56 PM
PeterLucas's Avatar
PeterLucas
ah ok,
they are a right coont to get the air out of then!
Old Jun 14, 2007 | 10:23 PM
charlie luciano's Avatar
charlie luciano
Rad could be blocked also as that causes the symptoms/trouble that you are having
Luciano
Old Jun 14, 2007 | 10:45 PM
AlexF's Avatar
AlexF
Its not holding pressure...
a leak...
Did you check?
Alex
Old Jun 15, 2007 | 01:06 AM
SS1's Avatar
SS1
Originally Posted by PeterLucas
ah ok,
saph related down the post have a read
http://www.fordscorpio.co.uk/cgi-bin...num=1133105627
might help
Old Jun 15, 2007 | 06:19 AM
coswurv's Avatar
coswurv
Water pump ?
Old Jun 15, 2007 | 06:36 AM
Spax's Avatar
Spax
I'd say your Rad is blocked
Old Jun 15, 2007 | 06:38 AM
Mr RS500's Avatar
Mr RS500
you havent got the car jacked up at the front have you ????
Reason i ask is because if you have , air gets trapped at the back of the head and will always air lock until the car is sat level
I blew the headgasket on my escoss when i changed the rad because i had it jacked up at the front when i was testing everything before i put the bumper etc back on the car
Old Jun 15, 2007 | 08:40 AM
PeterLucas's Avatar
PeterLucas
Cheers guys, will inspect rad today and make sure water pump is working.
Paul - I was told its a good idea to raise the front of the car when bleeding up, helps the air get to the expansion tank? Is this wrong info?
Old Jun 15, 2007 | 08:57 AM
PeterLucas's Avatar
PeterLucas
AlexF -
Do you mean a cylinder leakage test? or pressurising the cooling system and check for leaks?
I dont think the cooling system has any leaks because it holds pressure until the saftey release on the expansion cap lets go.
Old Jun 15, 2007 | 11:32 AM
CosKev3's Avatar
CosKev3
As above,rad would be my first thing to check
Before removing head
Old Jun 15, 2007 | 01:42 PM
AlexF's Avatar
AlexF
presure test the coolant system
it should hold 1.5-2.0bar for 2 mins... if not theres a leak
Alex
Old Jun 15, 2007 | 01:54 PM
PeterLucas's Avatar
PeterLucas
CosKev3 - Already done headgasket pal, to try and solve this problem.
Alex - I think you maybe right, been bleeding it runing it for about 30mins and managed to get it to not boil over, but found the coolant hose to the back of the head to be leaking Could it draw air in from there? Going to change this and try again.
Old Jun 15, 2007 | 02:11 PM
RichieST's Avatar
RichieST
have you replaced the expansion tank cap?
If the seal/relief valve has gone it will not hold pressure, unpressurised water boils at a cooler temperature than pressurised water, hence boiling over
Old Jun 15, 2007 | 05:09 PM
AlexF's Avatar
AlexF
It sure could...
change the cap as suggested above too and let us know how it goes!
Alex
Old Jun 17, 2007 | 06:04 PM
AlexF's Avatar
AlexF
Any news?
Old Jun 17, 2007 | 06:48 PM
The Youth.'s Avatar
The Youth.
Originally Posted by AlexF
Any news?
yes he posted the other day that the rad was found to be blocked solid, so all sorted now
steve
Old Jun 17, 2007 | 06:49 PM
Mr RS500's Avatar
Mr RS500
Pete
the air gets to the expansion tank as hot air rises I defo would never never never jack a 4x4 up at the front to bleed it
I know you have fixed the car anyway but still felt i should reply
Old Jun 17, 2007 | 06:51 PM
SapphyMike's Avatar
SapphyMike
Any news?
It was a blocked radiator - he's made another post about it.
Old Jun 17, 2007 | 06:54 PM
Hardeep_Singh's Avatar
Hardeep_Singh
It could be a number of things really.
how was the head and block checked? i'd have had them illiminated both by having them pressure tested before refitting the head gasket
Old Jun 17, 2007 | 07:02 PM
rapidcossie's Avatar
rapidcossie
head gasket changed before checking rad...wounder
Old Jun 17, 2007 | 07:23 PM
PeterLucas's Avatar
PeterLucas
Your telling me, although im glad I changed it in some ways...One less job for the future and got to check block, head condition etc etc.
She now doest go above the halfway mark on the temp gauge.
As previous post all sorted now thanks to all for advice
Old Jun 17, 2007 | 07:26 PM
rapidcossie
well done pete
Old Jun 18, 2007 | 07:28 PM
CosKev3's Avatar
CosKev3
Thats what the cryin smiley was after what I said for m8!!!!!!!
Glad you sorted it
Had same prob on my old car,half the rad blocked solid
Old Jun 18, 2007 | 08:22 PM
PeterLucas's Avatar
PeterLucas
Thanks guys
dombanks
Sep 21, 2015 08:38 PM
Chopshop85
Sep 12, 2015 06:42 PM
Rizlablue
Sep 6, 2015 09:58 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
fordjames
Ford Focus Diesel
Sep 3, 2015 10:20 PM
