xr3i engine tapping noise and idle probs
Old Jun 7, 2007 | 12:13 AM
chippyboy88's Avatar
chippyboy88
Default xr3i engine tapping noise and idle probs
hi all
just piked me self up an 1988 orion 1.6i for a song, mint contd.
the only prob i have is ther is a tapping noise from the engine that varies with the speed, me m8s dad has said could be the tappets but there suppost to be self adjusting, ive stuck me ear under there and it sounds more like its comeing from inside the intake not under the rocker cover,
the other little nag is the engine doesnt like to idle now and again, sometimes shes fine, next min ill pull up the revs drop and she cuts out,
and help plz
cheerz
Old Jun 7, 2007 | 12:26 AM
SafeChav's Avatar
SafeChav
The tapping is a fact of life with a CVH, you have 2 options - either buy a new cam AND lifters, or grin and bare it. Replacing just the lifters on there own WILL NOT cure the problem and is a waste of your money.
The idle problem is more than likely caused by an air leak, another common problem to MFI cars.
Old Jun 9, 2007 | 10:24 AM
MarkN's Avatar
MarkN
Idle problems are also caused by blocked breather systems on CVHs. Another firm favourite if the engine has not been well looked after.
Old Jun 9, 2007 | 12:02 PM
andyorion's Avatar
andyorion
With your idle problem, remove the air trunking to the throttle body and clean the throttle butterfly and air bypass with carb cleaner this will probably help with your idle problem as they tend to get a bit of carbon build up in there and can cause idle issues especially when cold/warming up. As for the tappet noise SC hit it on the nose if you want to stop it you will have to renew the cam and tappets together.
Old Jun 9, 2007 | 11:44 PM
chippyboy88
fanx lads il have a tinker about in the morning and see what i can do
cheers
bigryrs
Mar 28, 2016 09:11 PM
bigryrs
Fiesta RS1800/RS Turbo
14
Jan 21, 2016 09:54 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
track.focus'd
Aug 12, 2015 05:53 PM
