1.4CVH EFi Cylinder head rebuild probs :(
Old Jun 1, 2007 | 08:58 PM
Clarky139's Avatar
Clarky139
Default 1.4CVH EFi Cylinder head rebuild probs :(
Hey there, recently rebuilt cylinder head in my escort 1.4CVH EFi engine. Having problems with eratic idling. This is my first engine rebuild and am completly stumped. Had it off 3 times now trying to get it sorted but everytime it runs the same. When it runs idle its calm then gives a burst of gas every second or so as if the things about to stall. Ne help would be great.
Old Jun 1, 2007 | 10:51 PM
djmillsy's Avatar
djmillsy
Fife Radge
idle control valve
Old Jun 2, 2007 | 06:31 AM
Air leak, running lean and anti stall working ok!!
Old Jun 2, 2007 | 07:46 AM
Clarky139's Avatar
Clarky139
air leak from the inlet manifold or something? I was worried that there was a leak from the head gasket so it was getting poor compression? Would that cause it?
Cheers again!
Old Jun 2, 2007 | 09:29 AM
djmillsy's Avatar
djmillsy
Fife Radge
head gasket it would leak and be very shit and youd get no heater
Old Jun 2, 2007 | 05:38 PM
SafeChav's Avatar
SafeChav
I think you're wasting your time keep taking the head off, the problem is more than likely a lot simpler than that
As said look for air leaks and also give your ISCV a clean, they go sitcky and dont work properly
TPM961
Jan 15, 2018 10:50 AM
massivewangers
30
Oct 1, 2015 07:40 PM
dms04
Sep 11, 2015 01:57 PM
focus2351
Sep 9, 2015 09:33 PM
cossirob
Sep 3, 2015 09:17 PM
