juddering when accelerating - 1.6 xr2 CVH
Old May 30, 2007 | 02:48 PM
martint2k4's Avatar
martint2k4
Default juddering when accelerating - 1.6 xr2 CVH
Hi, my mate has put a 1.6 cvh engine into his mk3, the problem he's having is when he accelerates past about 2k revs, the revs go mental and jump up and down untile he changes gear, then when the revs get back up again it starts, has anyone got any ideas on what this could be? replaced the plugs, leads, dizzy cap and rotor arm but no improvement.
Old May 30, 2007 | 03:09 PM
SafeChav's Avatar
SafeChav
what fuel system is it running on
Old May 30, 2007 | 03:30 PM
martint2k4's Avatar
martint2k4
hmm not sure pal, think he has left everything else the same, the mk3 escort he has put it into was a 1.3, this help you any?
Old May 30, 2007 | 03:33 PM
SafeChav's Avatar
SafeChav
What has the engine got on it? Carbeurettor? MFI? EFI?
Old May 30, 2007 | 03:44 PM
martint2k4's Avatar
martint2k4
its a carb mate, he's got some twin webers here to fit but one step at a time i keep telling him haha, we have tried retarding and advancing the timing but still no joy,cleaned the carb out too still nothing, got us stumped.
cheers
Old May 30, 2007 | 03:47 PM
SafeChav's Avatar
SafeChav
ignition module breaking down?
plugs?
leads?
Dizzy cap & rotor arm?
Wiring fault?
Old May 30, 2007 | 03:53 PM
martint2k4's Avatar
martint2k4
tried plugs leads dizzy cap and rotor arm, not tried the ignition module, do you know if there is any quick fix to test the module? instead of going getting a new one first? also with you mentioning the fuel feed, is the 1.3 fuel gear he has got in there at the moment good enough to supply the correct amount of fuel he needs?
cheers again
Old May 30, 2007 | 03:59 PM
SafeChav's Avatar
SafeChav
you need equipment to test the module.
The main fuel line on the car will be the same, they are all 8mm, the pump on the 1.6 will be different i expect though, but thats on the engine anyway.....
Old May 30, 2007 | 04:33 PM
martint2k4's Avatar
martint2k4
thanks a lot mate youve been good help, will try and get hold of a new module and try that, would one off an rs turbo work? or they not have them?
thanks again
Old May 30, 2007 | 04:47 PM
SafeChav's Avatar
SafeChav
RS's don't have them.
Carbs are funny things aswell, just because you've cleaned it oout doesn't mean its ok, the weber ones in particular on CVH's ive had a lot of bad experiences with and i hate them
Old May 30, 2007 | 04:51 PM
martint2k4's Avatar
martint2k4
ok then mate thanks for your time, its bloody annoying with it kangarooing when you put your foot down, will have to get an ignition module to try, how hard is it to fit the twin 40 webers to this engine? do you need to uprate the fuel lines or anything?
cheers
Old May 30, 2007 | 04:58 PM
SafeChav's Avatar
SafeChav
no idea mate, i know the best part of fuck all about throttle bodies
Old May 30, 2007 | 05:00 PM
martint2k4's Avatar
martint2k4
cheers anyways pal, nice speakin 2 ya
Old May 30, 2007 | 07:03 PM
morrison's Avatar
morrison
hi m8 had them on a 1.6 cvh you need a 12v fuel pump like facet or something(at the back of your car)and remove the old 1,im not sure about this but the standerd pump is driven of the cam(please say if i am wrong)so this has to come off,i then put the blanking plate off the rs turbo over this hole
Old May 31, 2007 | 06:17 PM
martint2k4's Avatar
martint2k4
should be ok with the rs turbo blanking plates, got a few dead rs turbs ere,how much will i pick a pump up for you reckon? will we need new fuel lines?
cheers
Old Jun 5, 2007 | 01:04 PM
martint2k4's Avatar
martint2k4
well, sorted the problem, we took the ignition module off and cleaned the contacts, put it back on and it works smoothly, cheers for your help
Old Jun 5, 2007 | 01:13 PM
SafeChav's Avatar
SafeChav
mk3ste
Oct 17, 2021 10:09 AM
TPM961
Jan 15, 2018 10:50 AM
mondeomark
Sep 28, 2015 06:28 AM
sridgett
13
Sep 27, 2015 06:03 PM
