Do I need a setup when putting on a bigger Intercooler
Old May 24, 2007 | 08:41 PM
davidnormanuk's Avatar
davidnormanuk
Default Do I need a setup when putting on a bigger Intercooler
Talking to a mate today and he suggested taking the car to be setup due to fitting a bigger Intercooler. Is this needed when not upping the boost etc?
Dave
Old May 24, 2007 | 08:43 PM
abdr500's Avatar
abdr500
yes you do
Old May 24, 2007 | 08:55 PM
JohnP001's Avatar
JohnP001
Originally Posted by abdr500
yes you do
Really, what needs to change, as I'm thinking of putting a bigger cooler on my car?
John
Old May 25, 2007 | 08:48 AM
Cawood's Avatar
Cawood
im guess here but, it will be flowing cooler more dense air meaning now the fuel/air mixture will be out as it is now getting more air
that is why you need a setup
Old May 25, 2007 | 09:19 AM
JohnP001's Avatar
JohnP001
So are you saying that when fitting a bigger charge cooler, the car will run lean, so needs to be richend up? That could be a bit dangerous!!
Old May 25, 2007 | 10:53 AM
rssteve's Avatar
rssteve
surely the ecu will reconised the air is denser and add more fuel, just like if you took the car out on a cold night, the air would be denser than on a warm sunny day, and it will add more fuel automatically.
Old May 25, 2007 | 11:42 AM
nilrem's Avatar
nilrem
STOP!... Carry on
just a thought here... but if you fit a larger IC... then there is more room of the air to cool down and a slower flow of air through... wouldnt that mean less boost/pressure withing the inlet? probably not too significant, but would like to know either way... sorry for the thread jack...
in answer to your question... i havent heard of many people getting their engine set up after just changing the IC... so i wouldnt think so...
Old May 25, 2007 | 03:56 PM
davidnormanuk
I figured they'd be different views on this. The cold night thing did enter my mind though.
Old May 25, 2007 | 05:52 PM
It will flow the same air speed, if it it did not it would pressurise and go bang and the air was slower coming out than going in!!
The temp change will not be anything that the ECU wil not be able to cope with, not as much as the DIFFERENCE between a snowy winters day and a blazing hot summer day, thank god for AIR TEMP SENDERS!!
Old May 25, 2007 | 05:58 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
ur chip will sort it out........it should do......
Old May 25, 2007 | 06:46 PM
Stu.H's Avatar
Stu.H
Karl/NMS set my car up and mapped it with what was on the car, but mentioned about the S2 front bumper MASSIVELY restricting air flow.
He said to go ahead and mod the bumper, and no alterations to the map at this stage would be necessary.
Im guessing a remap would be needed if going from say a standard cooler to a large front mount...
Old May 25, 2007 | 07:15 PM
Stu @ M Developments's Avatar
PassionFords Creator
Depends on your current setup. Impossible to answer.
Old May 25, 2007 | 08:05 PM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
A mate of mine just put a FMIC on his starlet and its started detting its balls off
I'd get it checked out either way, for peace of mind if nothing else.
JK12
33
Apr 26, 2021 12:09 PM
imnoteasy
Sep 7, 2015 09:26 PM
atm
Sep 7, 2015 05:39 PM
Adam Graham
Sep 6, 2015 06:04 AM
gingeRS
Sep 4, 2015 06:29 PM
