oil light flickering when idling
Old May 24, 2007 | 06:27 PM
Tom_wheeler19's Avatar
Tom_wheeler19
Default oil light flickering when idling
Hi ive just bough a rs turbo and the oil light begins to flicker when im idling after ive given it a good pasting.... ive replaced the oil pressure switch and its still the same? should i use thicker oil... maybe its geting to thin when its hot? if any one has an idea please let me know. thanks.
Old May 24, 2007 | 07:11 PM
tonto's Avatar
tonto
If you have replaced the switch it sounds like you may have little or no oil pressure.If you visit your local FORD dealer they can check the oil pressure.This procedure will not cost much and then you will know if your oil pump is duff or not.
Paul
Old May 24, 2007 | 07:46 PM
Tom_wheeler19
but it seems to be fine as i pick up the reves a touch. do you know of the top of your head wat my oil pressure should be at?
Old May 24, 2007 | 08:07 PM
Is it idling at too slow a speed, this can cause it.
If it is ONLY doing it at idle when really HOT I would not worry, it is just a bit worn, or oil is too crap or thin, what oil are you using ?
Old May 24, 2007 | 09:49 PM
rinus_2005's Avatar
rinus_2005
i had that once on a trackday (it was 30degrees celcious outside).
Was driving on 10w40. changed it to 10w50. No problem since. however i also suspect my oilpump not really the best anymore.
On higher revs the pressure was/is fine now, just the hot idling was to low
Old May 24, 2007 | 10:42 PM
SafeChav's Avatar
SafeChav
More than likely early signs of a failing oil pump and/or the bottom end about to go........
Old May 25, 2007 | 07:36 AM
rinus_2005's Avatar
rinus_2005
i'm afraid so, but i've taken action to that, having a lowmilage 1.8ltr. zetec engine ready for zvh transplant. (it's just that the escort is stacked away due having a cossie project atm. which consumes much of available spare time)
Old May 25, 2007 | 11:52 AM
SafeChav's Avatar
SafeChav
rinus_2005...........i was replying to the thread author not you.........
hopper350
Sep 4, 2015 12:53 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
StephTell
Sep 2, 2015 06:31 PM
Adam-M
Aug 26, 2015 05:53 PM
