were can i get a top hat valve for my isc for antilag?
Originally Posted by GARETH T
been busy on the lathe have we ian?
i couldnt get the top hat to work right when i done one
Tapers can be a bitch to do....
its completly home made,,, even the bobbin,, so i can see this one getting charred
i have got an other idea i wanna try,,, might start making it next week! a revolving plug in the throttle body
you giant brained welshman you....
I did work out the length an size of wire necessary to lift the valve I made....
This the wire we used....
http://rswww.com/cgi-bin/bv/rswww/se...ukie&Nr=avl:uk
how did you work out the energy needed to lift your valve?
did you do it force=pressure x area, where pressure would be the differatial pressure across the valve area,,, and of cause area being the valve area?
I dont know where that one came from, but I do have some new ones in the workshop....what are they worth?
I cant quite decide if you would have a differential across the valve though....its subject to a vacuum on the plenum side and its that pressure it has to overcome....along with the weight of the valve itself and any return spring (if fitted)....we perfected it with a little trial and error...i reckon it would work, but might be on the top side of the output from the ecu.....
i hope your not near the 10amp output of a t6
,,, 120 watt
,,, 120 watt
Originally Posted by Roosie
big job or can a trained machinist do it
prefer to just goto a machinst say cut that off and stick this on.
i would just drill the holes out but i think the als will be to mild for my liking.
,,, 120 watt
,,, 120 watt
Red_bull
Aug 9, 2015 08:34 AM
