For people who have fitted a t34 to their cossie
Old May 23, 2007 | 04:18 PM
KSA-Cossie's Avatar
KSA-Cossie
Default For people who have fitted a t34 to their cossie
Did you have to modify the oil return pipe ? Mine was fitted the other day and today noticed very slight leak,mechanic is not sure if it's just the gasket or the pipe not quite sealing right,going to checj tomorrow when the fooker is cooler lol.
Old May 23, 2007 | 04:30 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
see if u can get a new gasket,cos they normally rip.....but unless ur man has had the alternator off the pipe is a right fuck on....so it may not be tightened proper............
Old May 23, 2007 | 04:31 PM
KSA-Cossie's Avatar
KSA-Cossie
Don't think he had the alternator off pete , thanks for the tip m8.
Old May 23, 2007 | 05:40 PM
Roosie's Avatar
Roosie
500bhp Cosworth in making
check the oil return aint touching the manifold mine was i had to bend it slightly as even tho i thought it was tightening th ebolts up it still had a slight gap between turbo and return pipe it was just catching on manifold
Old May 23, 2007 | 05:44 PM
KSA-Cossie's Avatar
KSA-Cossie
Thats what it looks like roosie had a butchers earlier on , where did you bend it and how much m8 ?
Old May 23, 2007 | 05:45 PM
xr4x4rs's Avatar
xr4x4rs
never had to bend my one
just went straight on if the core on teh turbo is aligned correctly
Old May 23, 2007 | 06:08 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
Had 3 t34s off various sizes and never had to mod anything simple bolt straight on.
Steve.
Old May 23, 2007 | 06:59 PM
KSA-Cossie's Avatar
KSA-Cossie
Old May 23, 2007 | 10:20 PM
CosKev3's Avatar
CosKev3
Originally Posted by xr4x4rs
core on the turbo is aligned correctly
Think thats the key thing m8
Slacken the core and move it round slightly
Has the turbo been on a 2wd????Usaul reason they don't quite line up right when put on 4x4
Old May 23, 2007 | 10:23 PM
mechanic28's Avatar
mechanic28
never had a problem fittin a T3 or a T34 on my 2wd sapp as said above sounds like the core may need to be adjusted!
Old May 24, 2007 | 04:25 AM
Roosie's Avatar
Roosie
actually i just remember i just rotated the core slightly while turbo is on car only slightly
Old May 24, 2007 | 06:46 AM
The CORE of the T34 and the T3 are the SAME so just might need rotating a bit, and easy when new.
Billy_RS
16
Oct 11, 2025 09:41 PM
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
kosienutter
31
Aug 22, 2015 09:55 AM
Red_bull
Aug 9, 2015 08:34 AM
