4x4 cossie front wheel bearing dust seals...
Are they necessary
Tried fitting them yesterday along with new bearings, and they (the seals) simply won't go in. One is bent and now in the bin, the other, well, not sure whether to try or not.
More seriously, if they are necessary (as I suspect they are), does anyone know where I can get two of them without buying a full bearing kit ?
Any tips on fitting them most appreciated
Thank you
Thank you
You can get them from Ford, as I had to get one. Can't remember how much it was, but I remember it was rather expensive for what it was. I’ve got a bearing installer kit, and used that to pull the seals into place. I used the old outer race, placed over the seal, and then pulled it in. Hope that helps.
I'll call the local dealership now
I got one of these : -
http://www.machinemart.co.uk/shop/pr...s/brand/clarke
But I had a special insert turned to fit the Cossie wheel bearings spot on.
Originally Posted by THE RADMAN
i use the old bearing outer race,place it on top of the dust seal and just tap gently around it
Bought a fitting kit yesterday, should get it today, along with the new seals hopefully
