fitting t34 to a small turbo cossie
Old May 14, 2007 | 09:30 AM
rs cosworth's Avatar
rs cosworth
Default fitting t34 to a small turbo cossie
hi i have a small turbo cossy and there is lots of play in the turbo shaft and a lot of smoke coming from the exhaust. My car has been chipped, uprated fuel pump, fuel regulator, exhaust and filter everything you need for around 285-290bhp.
I wanted to do the 350bhp bolt on conversion that Stu @ M Developments is working on so i have already bought a t34 unfortunatly the conversion isnt ready yet. I dont want to pay to rubild my standard turbo as i will change it once this conversion becomes available.
So my question is can i bolt the t34 on and and set it up to run about 285-290bhp or is the turbo to powerful. Im thinking the fueling would be okay if im still running the same power.
cheers
Old May 14, 2007 | 09:41 AM
Billabong's Avatar
Billabong
No you can't swap turbos and be safe. The T34 will flow more air than your std turbo - it's airflow (matched with suitable fuelling etc.) that gives the power.
Old May 14, 2007 | 09:51 AM
rs cosworth
i was thinking if my small turbo is 1.2 bar then it might be possible to run the t34 at .8 or maybe lower so that the air flow would be similar
Old May 14, 2007 | 10:01 AM
Stu @ M Developments's Avatar
PassionFords Creator
It will be reasonably safe at 14psi held if you dont push the revs up past 5000rpm mate. Ive tested it extensively on our own stage 1 calibration.
However... i CANNOT vouch that others calibrations will do the same.
Old May 14, 2007 | 10:43 AM
Andreas's Avatar
Andreas
Stu, would it overfuel at low revs since the small turbo produce boost lower down and as the t34 starts to build boost it would go towards a lean situation?
Old May 14, 2007 | 10:50 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
you are all forgetting the airflow meter, its not like changing a turbo on a shonky old L8 ecu car where its only reference is MAP.
Old May 14, 2007 | 11:07 AM
Billabong's Avatar
Billabong
Stu has given more specific info, with caveats - good for this particular guy.
I was answering in general, as I try to post with future readers in mind who may use the search facility and then think, wahay - I can bolt on a T3/04B on my small turbo, so I still stand by my answer
Old May 14, 2007 | 11:11 AM
Chip's Avatar
Chip
Future readers with ST cars will have an airflow meter too.
My point is the significant difference between doing with with a ST car and a BT car.
Old May 14, 2007 | 11:19 AM
Bills advice was good and safe, and had the car been set to 18psi as per small turbo, it would have melted.
Billabong's Avatar
Billabong
Point taken, but my point is DIY-ers - and imo, the post is now a different ball game with Stu's reply. It isn't a 'normal' situation, as the guy will be upgrading to Stu's EECIV development when ready, and wanted an interim solution.
So could he just bolt on a 'T34' and be safe - no, not without knowing specifics of his current chip and capping the boost - so the answer is still a general no, or 'ask your tuner'.
Old May 14, 2007 | 11:21 AM
Chip's Avatar
Chip
I agree, wasnt advising him to go and max it out down the M5, was just saying that I thought some of the people replying probably hadnt considered the airflow meter and the ecu's ability to compenstate to a certain extent for a difference in flow, where as an L8 etc has no chance.
Old May 14, 2007 | 02:40 PM
rs cosworth
thanks for the advice people i will fit the t34 and keep the boost low as im not looking for more power just want to stop the smoke because it looks bad when sat in traffic and im a bit worried incase the old turbo starts to break up and bits go into the engine.
hopefully Stu will not take to long sorting the conversion
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
kosienutter
31
Aug 22, 2015 09:55 AM
marky_g
Aug 15, 2015 10:43 AM
hazbaz1984
Ford Focus (All Models)
Jul 30, 2015 05:15 PM
