Starting in the morning
Old May 13, 2007 | 08:32 PM
BlueFiesta85's Avatar
BlueFiesta85
Default Starting in the morning
when i try to start the car in the morning it will not start unless i press the throttle a few times but before it use to start on the first click of the key. also once it intially starts the idling is very poor/lumpy, after bout 10-15 seconds it sorts itself out to normal. this is not right IMO but i believe it may have something to do with the cold start valve? any ideas to what could be the cause?
when the engine is warm and switched of and then started up again its fine no problems only gives hassle in the mornings and its not even that cold now
Old May 13, 2007 | 09:16 PM
addiction's Avatar
addiction
disconect the cold start valve and see if that makes a difference! its a blue plug at the back of the inlet manifold.
Old May 13, 2007 | 10:58 PM
SafeChav's Avatar
SafeChav
Cold start valve will cause it to flood when its cold, try unplugging it.
Its common for MFI cars to miss for a few seconds when first started but is nothing to worry about
Old May 13, 2007 | 11:36 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Mine sounds rough for 1 second when first started, cold start valve disconnected, clears almost right away and runs perfect even when left for a while! (I guess im lucky in that respect )
Old May 14, 2007 | 11:38 AM
Blakeya's Avatar
Blakeya
Almost defo the cold start valve as previously stated. The cailbration normally runs this valve for cold start when the ambient air temp is below -5DegsC (Very rare in the UK). Th starting problems seen with this valve connected & not in use is caused due to the Cold start valve going faulty & leaking fuel at all times. Disconnect it & forget it! It will be fine!!
Regards
Andy
Old May 14, 2007 | 08:02 PM
BlueFiesta85
any chance in changing or repairing it, is it ok disconnected all the time or should i reconnect it after the car is started up?
Old May 14, 2007 | 08:06 PM
Blakeya's Avatar
Blakeya
Leave disconnected & forget about it mate You could of course goto the expense of replacing it with a new one!!
Andy
Old May 14, 2007 | 09:26 PM
SafeChav's Avatar
SafeChav
Regards
Andy
Whoever told you that was lying, the cold start valve has nothing to do with cold running..........
Old May 15, 2007 | 08:42 AM
Blakeya's Avatar
Blakeya
SafeChav,
Who am i to get into an argument with you ?? Please explain what the cold start valve does exactly??
Regards
Andy
Old May 15, 2007 | 10:45 AM
SafeChav's Avatar
SafeChav
The cold start valve only operates when the engine is cold and the engine is being cranked.
As soon as the key is moved back from the cranking position it stops spraying. It's controlled by the thermo time switch which when it reaches a certain temperature stops the CSV's operation, and also has an unbuilt in heater to supposedly stop engine flooding if the starting process takes too long.
In the real world though the cold start valve always floods the engine and 99% of cars fitted with Bosch K/KE jetronic start noticeably better with it unplugged altogther
Old May 15, 2007 | 11:41 AM
Blakeya's Avatar
Blakeya
Andy
Old May 15, 2007 | 05:53 PM
BlueFiesta85
cheers once again gez
Old May 15, 2007 | 07:47 PM
SafeChav's Avatar
SafeChav
no worries
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
gingeRS
Sep 4, 2015 06:29 PM
kevin36
Sep 2, 2015 06:24 PM
