The best place to buy a knock sensor
whats it for?
Listends to the "knock" of the engine.
Retards ingiton if it senses "knock".
( I cant remember what knock is- but is deemed to be BAD)
Can be affected by things around the engine bay.
On CVH can be affected by the fact its on a Rattly CVH.
On a CVH either use an S1 Ecu which doesn't have knock sensor input (or Cossie etc ) OR remove from engine- still attached to loom - wrap shitloads of bubble wrap round it and cable tie out the way safely to prevent it sensing knock. Must still be conected to loom.
Jake
Jake
my subaru has one as standard, it retards the spark when it hears knock.
but the sensors play up so a lot of people have a second one with a led display so when it hits red back off.
you need to place it on the block away from other noises eg cams.
my scoobie one is under the intercooler
Originally Posted by avid-fan
when you fit it... if you buy one ..a nice place to put it
warning unit via leds
under your cd player tape thingy
on the left
on the left
http://www.thor-racing.co.uk/KNOCK_BLOCK_-LNK_KNKB.asp
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
adam151082
Aug 11, 2015 04:50 PM
