head back on, problems persist...
Old May 10, 2007 | 08:35 AM
RodgeRS_Turbo's Avatar
RodgeRS_Turbo
Default head back on, problems persist...
I finally got the head back on and got it all built back up (thanks to safechav for the collets n rings).
However it wouldnt start
I took a fuel line off, and cawed it over - no fuel coming out the injectors. I sprayed a little fuel in the throttle, and it fired up, so theres obviously a problem with the fuel pump.
I was just wondering, the fuel pump worked fine before I took the head off. Surely theres no plugs, sensors etc under the bonnet that would stop fuel coming through?
The only ignition lights I get are oil and parking - is this normal? (battery was flat right enough)
Thanks
Jamie
Old May 10, 2007 | 12:35 PM
gambit's Avatar
gambit
Default fuel pump
can you hear the pump prime (buzz) when you put it on ignition????
Old May 10, 2007 | 12:36 PM
gambit's Avatar
gambit
Default fuel pump
check the fuses first mate, before anything
Old May 10, 2007 | 12:57 PM
RodgeRS_Turbo
hi mate
nah no prime atall, got a mate to lie at the back of the car underneath when I put the ignition on, no buzz atall. When we spray the throttle it starts until the fuel we sprayed in is burnt away. Ive checked the fuse, but it was OK
Old May 10, 2007 | 01:02 PM
Barry R's Avatar
Barry R
check the pink relay in the drivers foot well
Old May 10, 2007 | 01:07 PM
RodgeRS_Turbo
hi mate how do I check this? should it click or something when I put the ignition on?
Old May 10, 2007 | 01:11 PM
Barry R's Avatar
Barry R
take the cover of it then push the contacts together when you try to start it.
Old May 10, 2007 | 01:24 PM
RodgeRS_Turbo
cheers mate will give it a go
cars away to get some welding though so will need to be the weekend
Thats 2 sleepless nights left
Old May 10, 2007 | 02:42 PM
Barry R's Avatar
Barry R
lol good luck with her
Old May 10, 2007 | 11:57 PM
SafeChav's Avatar
SafeChav
Personally i'd use a bridge wire in the fuel pump relay socket, bridge from the Red wire, to the Black/Red, and crank it over see what happens then.
Glad you got them ok, i did wonder
Old May 11, 2007 | 01:19 PM
RodgeRS_Turbo
it will be more than 2 sleepless night now, welder just foned me the floor is pretty rotten! So it will be a new footwell, 2 new rear floor pans, full sills and undersills
anyone want to buy a girlfriend??
Old May 11, 2007 | 03:10 PM
Barry R's Avatar
Barry R
pics please
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
ekjim
Aug 17, 2015 08:57 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
