Lifted my carpet...
Old May 7, 2007 | 09:30 PM
user 7082039239's Avatar
user 7082039239
Don't mention ze Vor
Default Lifted my carpet...
...and found rust. Bad or just normal, what do you think?
I think it could be a lot worse on a 19 year old motor.
Will get it sorted ASAP...
Old May 7, 2007 | 09:41 PM
Physio's Avatar
Physio
That isnt too bad at all mate
Old May 7, 2007 | 09:58 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
not bad at all mate, seen ALLOT worse, u could need 4 new floorpans for instance....
gus's Avatar
gus
could be worse....
that reminds me, must re paint the garage floor
Old May 7, 2007 | 10:12 PM
timturbo's Avatar
timturbo
Nothing to get upset over
Old May 8, 2007 | 06:30 AM
Stoo's Avatar
Stoo
That's mint compared to some I've seen
Old May 8, 2007 | 05:02 PM
xrmalin's Avatar
xrmalin
Thats about the same as mine in the same places aswell
Old May 8, 2007 | 05:49 PM
T28 RST's Avatar
T28 RST
Ok then
Did you find any money
Old May 8, 2007 | 05:54 PM
SafeChav's Avatar
SafeChav
It doesnt look too bad, but your all forgetting once you've run a grinder over that the true extent of it will be revealed.
That rear floor pan will almost certainly have spread all over the inner sill aswell.
Very common places to go but its never quite as simple as it looks.
Old May 8, 2007 | 06:43 PM
Turbo-Beal's Avatar
Turbo-Beal
Saw a 52 plate transit today with worst rust than that
Old May 8, 2007 | 08:07 PM
Rick's Avatar
Rick
New inner and outer rear sills needed.
Old May 8, 2007 | 08:56 PM
user 7082039239
Thanks for the kind words, guys.
Work is in progress, left-side iner sill only needed welding in a small patch and the seat mounting has been replaced aswell. rear side inner sill looks ok. At the joint to the floorpan both inner sills will be treated with "Fertan" to prevent a comeback of the dreaded tin worm.
Moreover I've found lots of healthy metal right next to the bad spots so I think it will be fine.
On the rear outer sills it's only a bit of surface rust, passed my "screwdriver test" no problem.
But the next targets are rear chassis rails and rear wheel arches...
Old May 9, 2007 | 12:06 AM
SafeChav's Avatar
SafeChav
Sorry to have be negative but realistically once rust has set into a panel the only way you will ever get rid of it completely is to remove that whole panel, but obviously with careful repair work and preventative measures it will greatly prolong its comeback.
A large drum of waxoyl is what you need.....
Old May 9, 2007 | 09:18 AM
user 7082039239
Yep, that's gonna be messy...
However I'll treat all parts where there was something like surface rust with fertan first. That not only seals rust like waxoil but is supposed to stop the corrossion process in the metal.
http://www.fertan.co.uk/
Old May 9, 2007 | 11:16 AM
daves2rs's Avatar
daves2rs
Waxoyl or bitchamin is fine on brand new rust free panels but I also recommend used diesel engine oil
Doesnt smell great but I have found it stops rust and keeps it from spreading further. Keeps the metal nice and supple
Old May 9, 2007 | 11:23 PM
fezzajsy's Avatar
fezzajsy
not bad at all
Old May 10, 2007 | 04:48 PM
Rick's Avatar
Rick
I need new rear arches
I can't be arsed with spraying the rear quaters though atm.
Old May 10, 2007 | 06:19 PM
Dan's Avatar
Dan
That's not brilliant really to people that actually do bodywork rather than people that think it's ok as there's not a lot of rust that the eye can see!
I've seen alot worse and yours isn't too bad but don't think it's a quick fix...
Old May 10, 2007 | 06:29 PM
Rick's Avatar
Rick
i certainly wouldnt patch the sills - just chop it all out and put new stuff in!
Old May 10, 2007 | 10:18 PM
lewis_lisa's Avatar
lewis_lisa
not too bad m8 may need sills though
paceo
Sep 25, 2015 08:05 PM
IainRS1700T
Sep 25, 2015 06:44 AM
cameron2
Sep 23, 2015 06:31 PM
Ronnie Scott
Sep 20, 2015 10:21 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
