oil pressure switch and speed sensor for an efi conversion
Old May 7, 2007 | 12:43 PM
Turbo-Beal's Avatar
Turbo-Beal
Default oil pressure switch and speed sensor for an efi conversion
Iv been connecting up my new ecu loom and i was wondering if the speed sensor and oil presure switch is diffrent on the efi setup? The speed sensor seems to have a diffrent plug and i was wondeing if the oil pressure swich is diffrent as the connector doesnt fit on the end Do i need the efi ones?
Old May 8, 2007 | 05:20 PM
Turbo-Beal's Avatar
Turbo-Beal
Anyone? Even you safechav
Old May 8, 2007 | 05:58 PM
SafeChav's Avatar
SafeChav
Oil pressure switch is the same the plug should fit
Speed sensor plug is different but is the same thing inside. I can sell you a proper jobby with the correct plug if it bothers you though
Old May 8, 2007 | 06:37 PM
Turbo-Beal's Avatar
Turbo-Beal
Cheers for that info m8. I might take you up on that if i turn up nothing at my local scrappy
mint_s2
Sep 2, 2015 08:58 AM
YODI
Aug 30, 2015 01:12 PM
Adam-M
Aug 26, 2015 05:53 PM
mrmann
Aug 20, 2015 11:24 PM
Perfmr2
Aug 6, 2015 07:30 AM
