Technical essay Archives A collection of topics you really shouldnt have missed first time round if your interested in the technical aspect of how these Fords work..!! Also many Workshop manuals available in downloadable format. Access is available to Gold Members only.
YB manual
Old May 6, 2007 | 06:57 PM
The Sludge's Avatar
The Sludge
garibaldi
Default YB manual
Probably been seen, but hey ho, if it helps
Foreword
The Sierra RS Cosworth is the latest product of Ford's long and fruitful collaboration with Cosworth, developers of some of the worlds most famous competition engines.
In addition to the 16 valve engine the Sierra RS Cosworth includes a considerable number of new components and systems, all designed to make it the most exciting and exhilarating saloon car ever sold by Ford.
This Technician Information has been developed to inform you, the Service Technician, about these new components and systems and their maintenance requirements.
More detailed information is included in the Special Workshop Manual on the Cosworth RS Sierra.
Service Training Programmes
October 1985
Q-P/GK- T -1
-2-
Contents Page
General 4
PART A - Engine, Engine Management and Turbocharger
1. The Ford Cosworth Engine 6
1.1 Engine Components 8
The Cylinder Head 9
Front Belt Drive 14
Crank Case Assembly 16
Oil pump and Lubrication Circuit 19
Engine Crankcase Ventilation 21
1.2 Repair Information 22
Important Notes on Cylinderhead - Removal and Installation 23
Important Notes on Cyl.head - Disassembly and Assembly 26
Further important Repair Notes 29
2. The Electronic Engine Management
2.1 General Description 32
2.2 System Components- Fuel System 32
- Air System 34
- Ignition System 36
2.3 System Sensors and Actuators 37
The Turbocharger 38
3.1 General Description 44
3.2 Boost Pressure Control 46
-3-
Contents Page
PART A - Engine, Engine Management and Turbocharger (cont'd).
Maintenance, Service Adjustments and System Checks 48
4.1 Maintenance 48
4.2 Service Adjustments 48
4.3 System Checks 50
5. Technical Data - Part A 53
-4-
General
The Sierra RS Cosworth is available as a 3 door Saloon car and is instantly recognisable from the way it sits low on the road and from its unique body panels. Front and rear wheel arch extensions cover the extra wide tyres mounted on 15" x 7" racing style light alloy road wheels. A new front grin panel with a single large cooling slot; a unique bumper with air dam; brake cooling pick-up point and louvres in the hood for optimum airflow are the main features of the front end.
A single plane areofoil/rear wing generates the positive down force required for traction and handling.
(RHD-Version shown)
-5-
General (cont'd.)
The 16 valve Cosworth engine presents the key element of the Sierra RS Cosworth. It uses the engine block from the proven Ford OHC engine but is completed with a host of new components and systems
such as
• The new cylinder head with its two camshafts to actuate the 4 valves of each cylinder
• A water cooled Garret turbo charger
• A Weber electronic fuel injection system and
• an ignition system made by Marelli.
However, in addition to its unique power plant, Sierra RS Cosworth houses a host of other new or modi*fied components and systems a Service Technician needs to be familiar with and these are
• A close ratio 5 speed transmission
• New clutch and driveshaft
• Limited slip differential similar to Scorpio
• Revised rear axle mounting
Revised front and rear suspension with power steering and specially tuned shock absorbers and springs to meet Sierra RS Cosworths demands on road holding and road adhesion
• Teves ABS braking system similar to the system used on Scorpio.
In addition to this exciting list of features the interior has been redesigned to match the vehicles sporty appearance and to provide the driver with the environment required for a car of this class.
-6-
General Information
The Ford Cosworth 2.0 litre 16 valve D OHC Engine with Turbocharger
-7-
General Information (cont'd.)
Sierra's high performance 16 valve engine has been developed by Cosworth in England, a company well known for its racing car engines.
The Ford 2.0 Itr: OHC regular production cylinder block forms the mainstay of this engine .
The valve cover bears the following identifications:
DOHC = Double Overhead Camshaft *indicating that the engine has two overhead camshafts
16 V = 16 valves
Turbo = Turbocharger
• Power = 150 kW (204 PS) at 6000 rpm
• Max. Torque = 278 Nm at 4500 rpm
• Max. Engine speed
- continued running: 6500 rpm
- intermittent running: 6800 rpm
Apart from the cylinder block, which has been selected from regular production, all other major components of the engine have been newly developed by either Ford or Cosworth or have been uprated to suit the engines high performance. Main feature of the engine is the 16 valve aluminium cylinder head with its two camshafts specially developed for this engine by Cosworth.
-8-
Engine - front cross section
-9-
1.1 Engine Components (cont'd.)
The Cylinder Head
The Cosworth light-alloy cylinder head has two overhead camshafts - one for the inlet side and one for the exhaust side.
A better volumetric efficiency is achieved by two inlet and two exhaust valves for each cylinder.
The valves are inclined and their "V" arrangement has an angle of 22,5ฐ.
Valve stem diameter - inlet valve 7.0 mm
- exhaust valve 8.0 mm
The exhaust valve stems are sodium filled for optimum cooling.
The exhaust valve stem is stepped and its upper end is 7.0 mm to enable identical valve retainers and collets to be used.
The valves are actuated directly via hydraulic valve tappets. This eliminates the need for valve gap adjustment in service.
Valve seats and guides are fitted in production by shrinking. Replacement can be done by specialists for this type of work.
Valve guides - inlet: Copper-alloy inner dia. 7.0 mm
exhaust : Copper-alloy inner dia. 8.0 mm
1 = Camshaft - outlet side
2 = Camshaft - inlet side
3 = Hydraulic valve tappets
4 = Exhaust valves - sodium filled
5 = Valve stem seals
6 = Inlet valves
7 = Valve guides
8 = Valve seats
-10-
1.1 Engine Components (Cylinder Head, cont'd.)
The valve stem seals have a press fit on the valve guides. Removal is done with special pliers, for installation a special installer tool is required (refer section "Cylinder head - remove and install").
Each camshaft is supported in five bearings with bolt-on bearing caps.
The cam bearings are machined in such a manner, that bearing liners are not required.
The bearing caps are marked 1 to 5 on the exhaust side and 6 to 10 on the inlet side with the counting starting from the front on both sides.
The front end of each camshaft is supported in a ball bearing to reduce the high start up torque transmitted through the timing belt of the sprocket wheel.
Camshaft support bearing
1 = Bearing cap
2 = Bearing retainer with bearing
Camshaft front bearing
1 = Camshaft sprocket wheel
2 = Bearing cap
3 = O-Ring
4 = Bearing retainer
5 = Ball bearing
6 = Camshaft
7 = Oil seal race
8 = Oil seal
-11-
The camshaft for the exhaust valves does not need this oil groove because of the position of the oil feed bore.
The oil feed bores are located on the side of the support bearings.
The camshaft for the inlet valves has bearing journals with oil grooves to ensure complete lubrication of the bearing surface.
Lubrication of the camshaft
1 = Oil supply bore
2 = Lubrication groove
The hydraulic valve tappets (bucket type) are supplied as an assembly. They should not be disassembled and must always be fitted into their original location.
1 = Camshaft
2 = Hydraulic valve tappets
3 = Valve stem
4 = Piston, cylinder and spring of the hydraulic valve tappet
5 = Tappet housing with oil chamber
-12-
The oil gallery of the cylinder head is fitted with a non-return valve which eliminates oil drain back after the engine is switched off
When starting the engine the anti-drain back valve opens for immediate lubrication of the camshaft journals and hydraulic tappets.
Anti-drain back valve in cylinder head
1 = Ball in closed position (engine switched off)
2 = Cross drilling
3 = Cylinder head bolt drilling (oil gallery)
4 = Main oil gallery
1 = Ball in open position (with engine in operation)
2 = Direction of oil flow
The cylinder head gasket differs from the standard OHC gasket in that it has revised openings to match the Cosworth cylinder head.
-13-
Components fitted to the Cylinder Head
Inlet side:
Inlet manifold (1)
Air chamber (2) with bolted on fuel rail (3), pressure regulator (4) and push fit fuel injectors (5).
Throttle housing (6) and elbow (7) .
The elbow is supported by a bracket (8) from the engine mounting. The elbow is fastened to the bracket by three pairs of special dished washers (9). This flexible mounting eliminates vibrations from the engine, which could affect the throttle position sensor. When disassembling, the position of the dished washers should be noted to ensure correct reassembling.
Outlet side: Two piece exhaust manifold (1) consisting of the primary manifold and the secondary manifold. Because of the high exhaust temperature, the manifold material consists of a heat* resistant cast iron (Ni-resist) .
The turbocharger is water-cooled and bolted to the exhaust manifold.
-14-
1.1 Engine Components Front Belt Drive
1 = Camshaft sprocket gear
2 = Timing belt
3 = Tensioner - timing belt
4 = Water pump
5 = Sprocket gear - auxiliary shaft
6 = Three belt pulley
7 = V-belt - power steering pump
8 = V-belt - alternator and water pump
-15-
1.1 Engine Components (Front Belt Drive, cont'd.)
The overhead camshafts and the auxiliary shaft are driven by a toothed timing belt directly from the crankshaft sprocket gear. The timing belt must be replaced in service every 80.000 km (50.000 miles).
• The sprockets for the camshafts and the auxiliary shaft are located by keys.
In contrast to the standard OHC-engine the Cosworth engine has a TOC marking on the sprocket gear for the auxiliary drive.
• The eccentric type belt tensioner allows a very precise setting of the timing belt tension.
The fan belt pulley on the crankshaft drives three belts, a matched pair for the alternator and the water pump and a single belt for the power steering pump.
Tensioning of the "V" belts for the alternator and the water pump is done on the bracket for the alternator. The procedure is similar to the one for the standard OHC-engine. Tension of the "V" belt for the power steering pump is achieved by tilting the power steering pump.
There are 4 teeth on the "V" belt pulley nearest to the engine. These teeth are separated by exactly 90ฐ. They initiate the pulses for the speed sensor (see "Engine Management").
The tooth next to the ignition timing . mark identifies the TOC position of piston NO.1. This position is reached when the flank of the tooth aligns with the marking on the front cover (see illustration). The TDC position
for the camshafts and the auxiliary shaft is set using the timing marks
on the sprocket gears and the markings on the housing.
TDC markings
1 = TDC position of cylinder "1"
2 = Ignition timinig (16ฐ BTDC)
-16-
Crank Case Assembly
Engine - side cross section
-17-
Cylinder Block
1.1 Engine Components (Crank Case Assembly; cont'd.)
• The cylinder block is a specially selected standard production OHC block.
Cylinder blocks selected have either a standard bore grade 2 or 3.
The bore size of the individual cylinders (either class 2 or 3) is stamped into the cylinder block behind the distributor; starting with cylinder NO.1.
Crank Case Assembly
The aluminium alloy pistons are either standard class 2 or 3.
• The pistons have a combustion bowl.
• The upper compression ring is chrome-plated.
Both compression rings are marked "TOP".
• The piston pin is fully floating and secured by snap rings.
Identification of cylinder bores and piston grades
Piston, Piston Rings and Piston Pin
1 = Production date and Manufacturer sign.
2 = Piston-standard class and arrow - engine front
3/4 = Compression rings with "TOP" mark 5 = Oil control rings
6 = Piston pin
7 = Snap ring
-18-
1.1 Engine Components (Crank Case Assembly, cont'd.)
• The connecting rods have been redesigned to suit high performance engine.
• The crankshaft is dimensionally similar with the standard OHC crankshaft. However, the crank*shaft is forged steel and bearing journals are specially hardened .
• The crankshaft is supported in five main bearings similar to the standard OHC engine. The centre main bearing is fitted with thrust half washers to control crankshaft endfloat, as on standard OHC engine.
• The main and connecting rod bearings are similar to the standard OHC engine but with improved bearing surface material. The procedure to measure bearing clearance is also similar. Note: The main bearing shells in the block have an oil groove.
• The crankshaft sprocket gear and the front and rear oil seals are similar to the standard OHC engine, but reinforced .
Most special tools for removal and installation are also carry over from the OHC engine. The installation tool for the rear oil seal has two additional fastening holes to suit the revised hole circle in the flywheeL
• The flywheel is new and it is fastened to the crankshaft by 9 instead of 6 bolts. The diameter of the flywheel is approx. 25 mm larger than on the OHC engine (without ring gear).
The flywheel and the crankshaft are balanced together during manufac*ture. The correct position of the flywheel to the crankshaft is ensured by unequal spacings between the fastening holes. The space between the fastening holes "A" is smaller than between the others.
Hole circle in the flywheel A = Smaller spacing
-19-
Oilpump and Lubrication Circuit
The oil pump is similar in design and operation to the pump fitted to the OHC engine.
The cover of the pump has been revised to connect an additional oil pipe.
Oilpump
1 = Oilpipe
2 = Four spray pipes
There are four spray pipes, one for each cylinder, which allow piston cooling by oil spray.
Position of the oil pump with spray pipe
An oil gallery at the front end of the engine block feeds oil to the valve train and the hydraulic tappets.
The oil pump draws oil from the sump and feeds it through an oil cooler and the full-flow filter into the main oil gallery which distri*butes the lubricant into the oil galleries in the same manner as on the standard OHC engine.
A non return valve in the oil gallery of the cylinder head eliminates oil drain back after the engine is switched off.
-20-
The Oilpan
The Ford Cosworth engine has an aluminium oil pan with internal baffle plate .
The gasket set for the oil pan is new.
The gasket features two cork layers with an aluminium gasket sand*wiched between them and 2 addi*tional rubber gaskets.
Since the aluminium oil pan gives the engine block additional strength, the cork/aluminium gaskets must be used.
The sealing wedges of the rear main bearing are part of the rubber seal and not separated as on the standard OHC engine.
Oilpan and gasket
1 = Oil baffle
2 = Cork/aluminium gasket
3 = Front rubber gasket
4 = Rear rubber gasket
Rubber seal - rear main bearing
-21-
1.1 Engine Components Engine Crankcase Ventilation
A = Throttle plate in fully open position
B = Throttle plate in closed position
1 = To aircleaner 4 = Filter
2 = Airchamber 5 = Oil separator
3 = Non return valve 6 = Oil drain pipe in oil separator
Waterpump and Thermostat Housing
The water pump has been carried over from the Sierra 2,0 Ltr. OHC engine.
Connected to the thermostat housing are the bleed hose for the cooling system and the coolant feed pipe to the turbocharger.
T
hermostat nominal temperature rating: 88ฐ C
Opening temperature: 88ฐ ... 94ฐ C
Thermostat Housing
1 = Bleed hose
2 = Connection for coolant feed pipe to turbocharger
-22-
General
This part of the brochure covers some important points on repair procedures. Complete and detailed procedures like engine disassembling and assembling are covered in the Sierra RS Cosworth Workshop Manual.
Most of the special tools are already available from the standard OHC engine. Additional new special tools are detailed below.
New or modified special tools:
New Special Tools Tool No.
Adaptor for valve spring compressor 21-024-06
Cylinder head alignment studs 21-128
Installer - valve stem oil seal (exhaust) 21 -1 29
Installer - valve stem oil seal (intake) 21-130
Remover - fuel feed hose 23-023
Modified Special Tools Tool No.
Crankshaft rear oil seal installer 21-011 0
Remover - crankshaft sprocket gear 21-028 A
-23-
Important Notes on Cylinder Head - Removal and Installation
Note: Before slackening the head bolts the engine should be allowed approx. 2 hours to cool off.
The fuel feed pipe can be removed using the new special tool 23-023.
Open special tool and slide over the fuel pipe as shown in illustration. Push tool against pipe fitting.
Remove the timing belt cover.
There are:
- two spacers fitted between the valve cover and the timing belt cover, - one spacer (with washer) screwed into the cylinder head
- and one spacer screwed into the engine block.
Before removing the timing belt the first cylinder should be set to TDC as follows:
- Turn crankshaft to a position where the flank of the tooth on the V-Belt pulley (1) aligns with the TDC marking on the cover.
- The timing marks of the two camshaft sprocket gears must align with the cylinder head upper edge.
Removal of fuel feed pipe
1 = Fuel feed pipe
2 = Special tool 23-023 3 = Fuel rail
Crankshaft in TDC position
1 = TDC marking
2 = Ignition timing mark (16ฐ BTDC)
Camshafts in TDC position
-24-
1.2 Repair Information (Important Notes on Cylinder Head - Removal and Installation, cont'd.)
- The timing mark on the sprocket gear for the auxiliary shaft must align with the marking on the engine block.
In this position, the distributor rotor will be in No.1 TDC position.
Slacken timing belt tensioner (one nut) and remove timing belt.
Important: Do not crank the engine with the timing belt removed. This will cause serious damage to the valve train and the pistons .
Slacken cylinder head bolts starting trom the middle of the head. Remove bolts with washers.
When installing the cylinder head gasket fit alignment studs as shown.
Auxiliary shaft and distributor rotor it, roc position
Slackening and tightening sequence for the head bolts
Alignment studs
-25-
Lubricate head bolts at threads and under bolt head and install bolts together with washers.
Tighten cylinder head bolts as follows:
Stage 1 requires to tighten all bolts 30-35 Nm.
Stage 2 requires to tighten all bolts to 67 -70 Nm following the sequence.
Stage 3 requires the bolts to be tighten in degrees of rotating using a special gauge tool.
Following the sequence, each bolt is turned 80ฐ - 90ฐ of rotation .
Check and ensure that the crankshaft, the camshafts, the auxiliary shaft and the distributor rotor are still in TDC position. Fit the timing belt in counter*clockwise direction starting at the auxi*liary gear.
• Pull belt tensioner by hand in clockwise direction against the timing belt and tighten fastening nut.
Crank engine several times in clockwise direction and subsequently one full turn counter - clockwise to TDC position.
Note: The engine must not be cranked beyond TDC position .
Using the belt tension gauge 21-113, check belt tension at the longest straight section (see illustration). If necessary adjust belt tensioner so that the specified tension of 9,5 to 10,5 is achieved .
Repeat complete procedure and recheck belt tension.
Crankshaft, camshafts, auxiliary shaft and distributor in tdc position
Checking and adjusting belt tension
Fit valve cover using a new, dry gasket. Then finger tighten all bolts. Subsequently torque bolts to specification, beginning with the inner bolts and ending with the outer bolts. Then tighten the flange bolts to specification.
• Install timing belt cover making sure the spacers and washers are correctly installed.
-26-
Cylinder Head - Important Notes on Disassembly and Assembly
To remove the camshafts, untighten bearing caps carefully in equal steps, remove caps and then lift the camshafts from the supports.
The bearing caps are marked by numbers starting at the front ball bearing 1 to 5 on the exhaust side and 6 to 10 on the inlet side.
The bearing journals of the camshaft for the inlet side have oil grooves.
The camshafts must not be inter*changed.
The bearing caps will fit one way only *incorrect installation is therefore not possible.
When fitting the camshafts, make sure that the front bearing retainers are flush with the bore in the cylinder head. The bearing retainers are pre*vented trom tilting by a screw and washer from below (see illustration).
First fit bearing caps 2 to 5 and 7 to 10 and tighten them equally starting with the inner ones.
Ensure both front bearing retainers are still flush before fitting the caps
1 and 6. Subsequently torque all nuts with the specified torque (see Technical Data).
Identification of bearing caps 1 = Support with ball bearing
Camshaft for the inlet valves Bearing journal with oil groove
1 = Retainer in flush position
3 = Securing screw
-27-
1.2 Repair Information (Important Notes on Cylinder Head - Disassembly and Assembly, cont'd.)
The camshaft once removed from the cylinder head can be disassembled as follows:
The camshaft sprocket gear is fixed on the camshaft by a keyway with
key (8).
Unscrew fastening bolt and remove the sprocket gear (1). Remove key (8) and pull oil seal race (2) and bearing retainer (6) from the camshaft (9).
Lever off oil seal (3) from the bearing retainer (6).
The ball bearing (5) has a press - fit in the retainer (6) and is secured by a snap ring.
The bearing can easily be pushed out of the retainer (if necessary with light hammer blow on the bearing outer ring or by using the handle of
a hammer).
New rubber '0' rings (7) should be used when reinstalling the camshaft.
The oil seal can also be replaced with the camshaft in situ. This requires removal of the sprocket gear and the oil seal race. Then, the oil seal can
be removed using the special tool 21-096.
The hydraulic valve tappets are supp*lied as an assembly and must not be dismantled.
Removal of a hydraulic tappet can be done easily using a suitable sucker.
Note: Removal of hydraulic tappets should not be done with a magnet.
Tappets should not be mixed up and should always be installed in their original sequence .
When installing, tappets should be lubricated .
When applying pressure to the hydrau*lic plungers some tappets may feel "soft" due to air in their hydraulic chamber. This may be ignored because it will disappear once the engine is running again.
Camshaft assembly
Special Tool 21-096
-28-
To remove the valves, the new adaptor 21-024-06 for the valve spring compres*sor 21-024 must be used. Make sure that the valves stems are not damaged by the valve spring retainer when it is pressed down to remove or install the valve collets.
Remove the valve retainers, the springs and the valves.
Remove the valve stem seals using a suitable tool (as known from the 1600 Diesel engine) as shown. Subsequently remove the lower spring retainer.
When assembling, first fit the lower spring retainers.
Then lubricate the new valve stem seals and press them onto the valve guides using the special tool 21-130 for the inlet side and the special tool 21-129 for the outlet side as shown.
Please remember, that the valve stem seals have different diameters
(inlet side - 7,0 mm, outlet side - 8,0 mm).
Lubricate the valve stems before inserting the valves into the valve guides.
Removal of valves
1 = Valve spring compressor 21-024
2 = Adaptor 21-024-06
Removal of valve stem seals
Installation of valve stem seals
In the case of replacing the valve stem seals with cylinder head in situ, a suitable adapter for the pressure hose should be used.
Note: For this procedure crank engine by hand, that all pistons are in the same position in the cylinder bores and then lock the crankshaft.
-29-
1.2 Repair Informations
The crankshaft V-belt pulley, the thrust washer and the sprocket gear can be pulled off the crankshaft by hand. If the sprocket gear has a tight fit then special tool 21-028 A should be used.
When fitting the sprocket gear the tapered side of the gear should face the camshaft. The V-belt pul*ley should be fitted with its teeth closest to the engine.
The thread of the fastening bolt for the auxiliary shaft gear is plastic coated. When reinstalling always use a new bolt.
The flywheel is balanced together with the crankshaft.
The position of the flywheel to the crankshaft is fixed through unequal spacings between bolt holes i.e. the space "A" between two holes is smaller than between the others .
The installer for the crankshaft rear oil seal is from the tool set for the standard OHC engine. However, the tool has two additional fastening holes to suit the revised bolt hole circle.
1 = V-belt pulley with teeth
2 = Thrust washer
3 = Crankshaft sprocket gear
4 = Fastening bolt-auxiliary shaft gear.
Bolt thread is plastic coated.
Flywheel fastening to crankshaft
A = Reduced spacing
1 = Special tool with two additional fastening holes
-30-
1.2 Repair Informations (Further important Repair Notes, cont'd.)
Crankshaft bearing clearance should be measured using "Plastigage" as on the standard OHC engine.
• The main bearing caps are marked with an arrow which should point to the front of the engine.
• The rear main bearing cap is cham*fered on both sides to ensure cor*rect seating on the cylinder block. When installing the bearing cap, the chamfered edge should be coated with sealer (Loctite 518). Make sure the sealer is not applied to the flat contact area.
Rear main bearing cap
Sealer to be applied only to the chamfered edge.
Crankshaft endfloat is controlled by thrust half washers. Their respective position must be marked when removing.
The connecting rod big ends and bearing caps are numbered. These numbers should be noted before removing the bearing caps and the caps should always be installed in their original posi*tion.
When installing the pistons to the connecting rods the arrow on the piston crown must point to the front of the engine. The bearing retainer groove in the connecting rod should point to the auxiliary shaft.
-31-
1.2 Repair Informations (Further important Repair Notes Other Repairs, cont'd.)
Before installing the oil pump, fit the oil pump driveshaft. The longer end of the shaft should point to the distributor (see illustration).
Fit oil pan gasket as follows:
Coat sealing wedges with sealer (Loctite 518, see illustration). Insert them into the groove of the rear main bearing cap and press them fully home.
Apply sealer to the ends of the front rubber seal and the cork gasket and install. Slide the ends of the cork gasket under the ends of the rubber gasket.
Coat the threads of the oil pan fastening bolts with Loctite 270 and tighten them in three stages to the specified torque (see technical data).
If the distributor was removed, installation should proceed as follows:
- Hold distributor so that the spring clip points to the engine and that the distributor rotor points away from the engine (see illustration).
- When inserting the distributor the rotor will turn to its correct position and point to the marking for cylinder No.1
Note: When installing the distribu*tor, the crankshaft, the camshafts and the auxiliary shaft must all be in TDC position.
Oil pump driveshaft
Position of the distributor rotor when installing the distributor
1 = Marking cylinder No.1
-32-
2. Electronic Engine Management
The Sierra Cosworth is fitted with a combined Electronic Engine Management System with fuel injection from Weber and ignition system from Marelli.
The electronic fuel injection system is in many respects very Similar to the EFI system available for Scorpio and Sierra vehicles.
An electric fuel pump feeds fuel from the fuel tank through a fuel filter to the fuel rail with its four injectors (one per cylinder).
The injector "on" time is individually controlled for each cylinder by the Electronic Control Unit ECU.
Inlet air passes from the aircleaner through the turbocharger, the air to air charge cooler, the throttle body, the airchamber and inlet manifold to the individual cylinders.
Electronic Engine Management - Fuel and Air System
1 = Fuel tank A = Air cleaner
2 = Fuel pump B = Turbocharger
3 = Fuel filter C = Air to air charge cooler (intercooler)
4 = Fuel rail D = Throttle bOdy
5 = Pressure regulator E = Air chamber
6 = Fuel injector F = Inlet manifold
7 = Electronic Control Unit (ECU)
8 = Pressurised fuel
9 = Non-pressurised fuel
-33-
2.1 General Description (cont'd.)
The ignition is of the inductive discharge type with dwell control in the ignition module and the advance curves are stored by the ECU.
Electronic Engine Management - Ignition System
1 = Electronic Control Unit (ECU)
2 = Distributor with Phase sensor
3 = Crankshaft pulley
4 = RPM / TDC-Sensor
5 = Ignition module
6 = Ignition coil
A number of sensors feed a continuous stream of information signals to the ECU module thereby enabling the ECU to determine the required air fuel ratio and the spark timing.
The individual components of the engine management system are described on the fOllowing pages.
-34-
2.2 System Components - Fuel System
The Fuel Pump
• The electric fuel pump is of roller type and is controlled by the ECU.
• The pump incorporates a non-return valve which can be replaced in service.
• The non-return valve maintains the system pressure during cranking.
• Fuel pump operation is controlled by a relay which switches the fuel pump on and off when the engine is started or stalls.
• The pump cannot be repaired and must be replaced as a unit when defective.
• Both, the power relay for the ECU and the fuel pump relay as well as the Fuses are located in a special box in the engine compartment.
The Fuel Filter
All fuel passes through a fuel filter.
The filter must be replaced at regular intervals as detailed in the service voucher booklet.
The Fuel Rail
All fuel from the filter passes to the fuel rail which is connected to all the injectors and ensures that they are supplied with fuel at the same pressure.
Relay location
1 = Power relay (brown socket)
2 = Fuel pump relay (yellow socket)
3 = Fuse - Power relay 15 A
4 = Fuse - Fuel pump relay 20 A
Fuel rail and pressure regulator
-35-
2.2 System Components - Fuel System (cont'd.)
The Pressure Regulator
To ensure accurate fuel metering and extend the capacity of the injectors it is necessary to reduce the fuel rail pressure at idle and low power usage whilst increasing the fuel rail pressure under boost conditions. This is achieved by feeding a inlet manifold pressure signal to the fuel pressure regulator:
The Fuel Injector
The injectors are solenoid operated valves.
The quantity of fuel injected depends only on injector open time and fuel rail pressure.
Injection is in a cone shape and the feed pressure 3,0 bar (modified by manifold pressure acting on the diaphragm of the pressure regulator), sufficient to cause a very fine spray.
Injectors cannot be adjusted or repaired and have to be replaced as a unit when defective.
Pressure regulator cross section
1 = Fuel from fuel tank
2 = Fuel return
3 = Diaphragm
4 = Connection, inlet manifold pressure
5 = Inlet manifold pressure?
-36-
2.2 System Components - The Air System The Air Cleaner
• The air cleaner has a replaceable filter cartridge which can easily be removed in service.
The Throttle Body
The throttle body (4) includes the throttle plate. The throttle plate setting screw (5) is factory set and sealed. It should not be altered in service. If the engine idle speed is not to specifications at the first servicing (1500 km), it can be adjusted by means of the basic idle speed control screw (see "Service Adjustments").
Bolted on to the throttle body are the idle speed control valve (.6) and the throttle position sensor (7). These are explained in the section covering "Sensors and Actuators",
The Air Chamber and Inlet Manifold
The throttle body is bolted on to the air chamber (3). Also fitted to the air chamber are
- the inlet air temperature sensor (11),
- the vacuum connector for the Manifold Absolute Pressure sensor (9),
- the vacuum connector for the fuel pressure regulator (10),
- the vacuum connector for the aircharge by-pass valve (13),
- and the vacuum connector for the crankcase ventilation filter (12) .
The air chamber is bolted on to the inlet manifold (2). The fuel rail with the plug-in fuel injectors (1) are fitted to the inlet manifold.
1 = Fuel rail with injectors
2 = Inlet manifold
3 = Air chamber
4 = Throttle body
5 = Throttle plate setting screw
6 = Basic idle speed control screw
7 = Throttle position sensor
8 = Idle speed control valve
9 = Connector - manifold absolute pressure sensor
10 = Connector - fuel pressure regulator
11 = Inlet air temperature sensor 12 = Connector - crankcase ventilation filter
13 = Connector - aircharge by-pass valve
14 = Connection - boost pressure gauge
-37-
2.2 System Components - The Ignition System
The Distributor
The distributor - make Marelli - is driven by the auxilliary shaft as on the standard OHC engine.
A Phase sensor, located opposite a cam having two teeth separated at 90ฐ to each other, is fitted inside the distributor. At the passing of a tooth the sensor delivers a signal to the ECU. This signal is similar to the signal supplied by an RPM / TDC*sensor fitted at the crankshaft pulley.
Both the signal from the distributor and the RPM / TDC-sensor enable the module to identify the phase of each cylinder. This information forms the basis on which the ECU module decides on spark timing and fuel injection.
The Ignition Coil and Ignition Module
The Motorcraft ignition coil and the ignition module (make Marelli) are both fitted to the left fender apron
The ECU sends a Spark-out (SPOUT) signal to the ignition module to trigger an HI pulse by switching the coil primary circuit off.
The Spark Plugs
The Sierra RS Cosworth is fitted with Motorcraft spark plugs AGPR 901 C.
Distributor
1 = Phase sensor
2 = Cam with two teeth
RPM / TDC-Sensor
1 = Tooth on crankshaft pulley
2 = Sensor
-38-
System Sensors (input) and Actuators (outputs)
A = ECU
B = Engine
Sensors
1 = Throttle Position Sensor (TPS)
2 = Manifold Absolute Pressure Sensor (MAP)
3 = Air Charge Temperature Sensor (ACT)
4 = Engine Coolant Temperature Sensor (ECT)
5 = Engine RPM / TDC-Sensor
6 = Distributor-Phase Sensor
Actuators
7 = Fuel Pump
8 = Fuel Injectors
9 = Idle Speed Control Valve (ISCV)
10 = Boost Pressure Control Valve (sometimes called AMAL)
11 = Ignition Module
-39-
General Description
The ECU module controls all fuel and ignition requirements of the engine by receiving, comput*ing and comparing sensor signals with its own permanent memory. Then it sends out signals to a series of actuators which control spark timing and fuel release.
The ECU is fitted behind the glove box and can be reached easily through a separate access lid. A 35 pin plug connects the ECU to the wiring loom.
Located next to the module are:
- the CO adjusting screw,
- a green, a blue and white cable for retarding the spark timing to meet fuels with lower octane rating
- and a self test connector:
Power to the ECU is supplied with a feed from the battery, via a relay.
For details see "Maintenance, Service Adjustments and System Checks".
ECU
1 = CO adjusting screw
2 = Module with multiplug
3 = Cable for retarding the spark timing
4 = Self test connector
-40-
2.3 System Sensors and Actuators (cont'd.)
The system sensors (inputs) are:
The Throttle Position Sensor (TPS)
This unit is fitted to the throttle shaft and senses the throttle position. At idle speed voltage is 5.0-4.5 volts and at full throttle the voltage drops to 0.5 volt.
The switch can be adjusted within the limits of its elongated fastening holes. (See "Service Adjustments".)
The Manifold Absolute Pressure (MAP) Sensor
The MAP-Sensor is fitted to the left fender apron and connected to the air chamber by a hose.
Depending on the manifold pressure, the Sensor regulates between 0.25 to 4.75 volts. If manifold pressure exceeds 0.9 bar, the sensor signals the ECU to cut-off fuel discharge by the injector valves.
The sensor cannot be adjusted or repaired.
The Air Charge Temperature (ACT) Sensor
This sensor is of the NTC resistor type, its resistance decreases as tempera*tures increase.
The ACT is screwed into the air chamber and can only be replaced as a unit if defective.
At 0ฐ C, for example, the resistance is 9.75 kOhm and at 70ฐ C the reading is 0.53 kOhm. Depending on the signal received from the ACT, the ECU module will vary the injection and ignition timing and also affect operation of the Turbocharger: (For further details see section "Turbocharger".)
-41-
Engine Coolant Temperature (ECT) Sensor
The ECT is also of NTC resistor type and its operating range is identical to that of the ACT.
The ECT is screwed into the cylinder*head and its signal to the module affects injector open time and idle speed.
Engine RPM and tdc Sensor
This sensor is bolted to the engine front end. The crankshaft pulley has 4 identical teeth spaced at precisely 90ฐ. The sensor sends a signal to the module whenever a tooth passes the sensor. From this signal the module determines engine speed (RPM) and the TDC*position of each piston (crankshaft position) .
The gap between the sensor and the teeth on the crankshaft pulley is 0.4 to 1.0 mm and is factory set (see service adjustments).
The Phase Sensor-Distributor
This sensor is located inside the distributor. It's signals (and the signals from the RPM/TDC sensor) enable the ECU to identify the phase of each cylinder following the firing order.
The gap between the sensor and the teeth of the distributor cam is 0.2 to 0.3 mm and is factory set (see service adjustments).
RPM/TDC-Sensor
2 = Sensor
A = 0 to 1.0mm
1 = Sensor
2 = Tooth
A = 0.2 to 0.3 mm
-42-
After comparing sensor signals with its own permanent memory, the ECU sends out signals to a number of actuators (outputs).
These actuators are:
The Fuel Pump
The fuel pump is switched on and off via a relay when the engine is started or stalled.
The Fuel Injectors
The ECU provides accurate control of the solenoid operated fuel injectors to discharge fuel.
The Idle Speed Control (ISC) Valve
This unit regulates the engine demand for air depending on engine temperature, engine load, or switched on accessories.
When the throttle plate is in the closed position and engine speed is within the controlled idle speed range, air is allowed to bypass by means of the idle speed control valve. The valve, which is controlled by a variable current from the ECU, adjusts the air flow into the engine in order to maintain a constant idle speed.
With cold engine, the valve regulates speed above 1200 RPM.
With hot engine, the valve regulates speed below 1200 RPM only.
The valve is non-adjustable.
-43-
The Boost Pressure Control Valve (AMAL)
This solenoid valve is directly connect*ed to the high pressure side of the turbocharger by a hose. Depending upon whether the valve is open or closed it will either "vent-off" a portion of the boost to the inlet side of the compressor (valve open) or direct it to the waste gate actuator (valve closed). For further information see section "Turbocharger",
The Ignition Module
This module receives a signal from the ECU module to release a spark.
2.4 Further Important Notes on Electronic Engine Management
Limitation on Engine Revolutions
For information see section "The Turbocharger".
Warning Light-Engine Management Failure
This warning light is located next to the auxiliary warning lights.
When the light switches on, the driver will be informed, that a failure in the engine management system have occured. For further information see section "Maintenance, Service Adjust*ments and System Checks".
-44-
3. The Turbocharger
The turbocharger (make Garrett, type T3) with integral wastegate and intercooler, used for the Sierra Cosworth engine, is similar to the turbocharger that is fitted to the Escort RS Turbo engine. In addi*tion, the Sierra Cosworth turbocharger is watercooled. The principle of operation of both turbo*chargers are similar and described in the Escort RS Turbo Workshop Manual.
The turbocharger is designed to give boost pressure at relatively low engine speeds, thus giving a useful increase of torque under normal driving conditions.
The operation boost pressure is 0.7 bar: Maximum boost pressure is limited to 0.9 bar above atmospheric.
Turbocharger assembly
1 = Turbine housing with integral waste gate
2 = Watercooled intermediate housing
3 = Wastegate actuator
4 = Connection - boost pressure control Valve to Wastegate actuator
5 = Connection - Compressor to boost pressure control valve
6 = Compressor housing
7 = Exhaust manifold assy.
8 = Boost pressure gauge
9 = Intercooler
10 = Air cleaner
11 = Relief connection (vent)
12 = Boost pressure control valve
13 = Air Charge Temperature (ACT) Sensor
14 = ECU
-45-
3. The Turbocharger
3.1 General Description (cont'd.)
The lubricating oil for the turbocharger is taken from the main oil pressure system of the engine (the oil feed pipe is connected to the oil pressure switch). The return oil flows back to the sump through a pipe of relatively large cross-section.
The watercooled intermediate housing of the turbocharger prevents over*heating of the turbine shaft bearings and the turbocharger housing. After switch-off the coolant will prevent excessive temperature build-up of
the unit.
The coolant feed pipe for the turbo*charger intermediate housing is connected to the thermostat housing . The return coolant flows back to the expansion tank.
The integral wastegate regulates the flow of exhaust gases. Due to the engine's demand for boost the exhaust gases are either allowed to the exhaust turbine or through the bypass duct into the vehicle exhaust system circumventing the exhaust turbine.
The wastegate actuator, which is connected to the wastegate by a rod, is controlled by the ECU via a boost pressure control valve.
Pipe connections
1 = Oil feed pipe
2 = Oil return pipe
3 = Coolant feed pipe
4 = Coolant return pipe
1 = Wastegate actuator
2 = Actuator rod
3 = Wastegate
4 = Turbine housing
5 = Turbine impeller
An intercooler (air to air radiator) is fitted to cool the charge air.
The turbocharger is maintenance-free.
-46-
3. The Turbocharger
The Sierra RS Cosworth is equipped with electronic/mechanical boost pressure control.
The ECU is programmed to control boost via a solenoid operated control valve on receipt of sensor signals .
The boost pressure control valve is directly connected to the high pressure side of the turbocharger by a hose.
Depending upon whether the valve is open or closed it will either "vent off" a portion of the boost to the inlet side of the compressor (aircleaner) or direct it to the wastegate actuator
1 = Exhaust turbine
2 = Compressor impeller
4 = Boost pressure control valve
5 = Air charge temperature (ACT) sensor
W = Wastegate connection
C = Compressor connection
R = Relief connection (vent)
M = ECU
With engine in operation, the boost pressure control valve is open, allowing air charge to "vent off", depending on receipt of signals from the ECU.
Boost pressure control valve in situ
1 = Hose - Wastegate Actuator
2 = Hose - Turbocharger high pressure side
3 = Hose to aircleaner ("vent off")
Boost pressure control valve open, allowing air charge to "vent off', The wastegate is closed.
-47-
3. The Turbocharger
3.2 Boost Pressure Control (cont'd.)
The boost pressure control valve will be closed gradually when the engine speed is above 6000 RPM or when the air charge temperature exceeds 70ฐ C.
When these signals from the RPM / TDC* sensor and the Air Charge Temperature (ACT) sensor are received by the ECU, it closes the solenoid control valve gradually applying full turbo pressure to the wastegate actuator which then fully opens the wastegate. A high amount of the exhaust gases are allowed through the bypass duct into the vehicle exhaust system circum*venting the exhaust turbine. The boost pressure is reduced to approximately 0.3 bar.
The reduction in boost pressure will reduce the temperature to acceptable working level.
The By-pass Valve (Recirculating Dump Valve)
A special by-pass valve (located next to the intercooler) is directly connected to the air chamber. the intercooler and the inlet trunking by hoses. The bypass valve prevents a pressure build up of air charge in front of the throttle plate when the throttle plate is suddenly closed. With the throttle plate in closed position, the vacuum in the air chamber opens the by-pass valve and an amount of charged air will be by-passed from the intercooler back to the inlet trunking.
Boost pressure control valve closed allowing air charge to open the wastegate via the actuator
By-pass Valve
1 = Valve
2 = Connection to air chamber
3 = Connection to intercooler
4 = Connection to inlet trunking
In case the boost pressure exceeds 0.9 bar, the fuel injection at the injector valves will be interrupted.
At 6500 to 6800 engine RPM, the boost pressure is reduced to approximately 0.3 bar by the boost pressure control valve.
At 6800 to 7000 engine RPM, the ECU is programmed in such a way to interrupt every second injection (the engine will remain in performance but without increase of engine RPM).
At speeds above 7000 RPM, injection will cut off totally, controlled by the ECU.
-48-
4. Maintenance, Service Adjustments and System Checks
4.1 Maintenance
The routine service schedule for the Sierra RS Cosworth is similar to the Sierra with the standard OHC-engine:
• First free Service at 1500 km
• Interim Service at 10.000 km and
• Standard Service at 20.000 km.
There are some exceptions which are included in the Sierra Service Voucher Booklet.
• The timing belt must be replaced at 80.000 km.
Throttle Plate Setting Screw
This screw is factory set and sealed and must not be altered in service.
Basic Idle Speed Control Screw
If the engine idle speed is not to specifi*cations at the first servicing (1500 km), it can be adjusted by means of the basic idle speed control screw
Disconnect multiplug from idle speed control valve, untighten locknut and adjust idle speed screw to achieve correct idle rpm with warm engine.
Idle speed: 850 rpm.
Note: After refitting the multiplug, the engine will raise to high engine rpm for a short period of time.
Throttle Position Sensor (TPS)-Adjust
After disassembling and re-assembling the switch can be adjusted within the limits of its elongated fastening holes.
Loosen fastening screws so that the housing snaps back by spring pressure to the original factory set throttle
plate adjustment.
1 = Idle speed control valve (ISC)
2 = Throttle plate setting screw
3 = Lock nut
4 = Basic idle speed control screw
-49-
4.2 Service Adjustments (cont'd.)
Adjustment of Idle Mixture
Specified mixture CO at idle: 1-1.5% CO
The CO adjuster screw is located on the left hand side of the module multi plug.
Using a suitable tool carefully remove the tamper-proof plug thereby making sure that the tool does not penetrate the plug by more than 3 mm.
Excessive penetration may cause damage to the potentiometer located behind the adjuster screw:
To adjust CO the adjuster screw can be turned from stop to stop.
After correct adjustment the screw should be protected with a tamper proof plug.
Ignition Timing
The ignition timing (16 BTDC) cannot be adjusted in Service. The ignition timing is controlled by the ECU module and depends on engine temperature, load and manifold absolut pressure.
When replacing the distributor; the distri*butor must be inserted with the rotor aligning correctly with the TDC marking for cylinder NO.1 on the housing. A devi*ation of up to 4ฐ will be compensated by the ECU module.
Retarding the Ignition Timing
To meet fuels with lower octane rating the ignition timing can be retarded electronically by 2. 4 or 6ฐ by connecting the cable connectors (near the RH side of the ECU module) in various ways.
1 = Mixture control screw
2 = Cable for octane adjust
A = Distributor
B = RPM / TDC-Sensor
1 = Phase-sensor
2 = TDC marking - cyl. No.1
3 = Fastening bolt
4 = Fastening bolt
5 = 0.4 - 1.0 mm
Connections
Green plug to white plug = ignition retarded by 2ฐ
Blue plug to white plug = ignition retarded by 4ฐ
Green and blue plug to white plu = ignition retarded by 6ฐ
(The white plug connects to chassis earth).
Adjusting the RPM / TDC Sensor
The air gap between the sensor and the eam should be 0.4 to 1.0 mm.
To adjust the air gap, the fastening bolt for the sensor must be untightened to enable resetting of the sensor.
-50-
4.3 System Checks
Quick Test
The ECU module includes an internal selftest facility .
A warning light on the instrument panel will switch on if there is a defect in one of the sensor circuits.
Simultaneously a coded signal is fed to the test connector near the RH side of the ECU module
Connecting an LED tester to this test plug allows a quick test to be carried out on the following sensor circuits:
- RPM / TDC sensor
- Sensor - cylinder phase (distributor)
- Sensor - inlet air temperature (ACT)
- Sensor - engine coolant temperature (ECT)
- Sensor - inlet manifold absolute pressure (MAP)
The LED tester for the EEC IV-system (Loewener tool No. 0132060 or
Churchil tool No. 0472060) may be used.
The quick test is carried out with the engine not running but with the ignition switched on.
During the quick test the ECU module transmits codes in the form of electrical pulses.
Warning Light - Engine Management failure
Quick Test
1 = Test connector
2 = LED Tester
3 = Cable - battery plus
stevecfrst1
Sep 30, 2015 05:18 AM
IainRS1700T
Sep 25, 2015 06:44 AM
THE RADMAN
Sep 19, 2015 12:57 PM
markk
Sep 9, 2015 08:11 AM
fuzzy
Sep 4, 2015 10:11 PM
