Saff Cossie 4x4 fuel pump
Old May 2, 2007 | 08:41 PM
Default Saff Cossie 4x4 fuel pump
Hi people have any of u with saff cossies 4x4 had problems with ur wiring for the fuel pump.What is the least voltage that the fuel pump will run on.If i had 2 wire up a new relay for the fuel pump without an ignition live how wud i do it.Any advice wud b nice.
Old May 3, 2007 | 08:21 PM
Ive had another look at my car tonight n found that.When crankin the engine the permant live wire(red) to the fuel pump relay(yellow) is turning from a live 2 an earth.Sud it b a constant permant live all the time.Cud i not just use a new permant live wire straight from the battery to the fuel pump relay. Thank u for any help
Old May 8, 2007 | 07:41 PM
The auto electrician came today n said it was a fuse relay holder which was badly pitted So he cut it out n replaced it with a new fuse holder. Ive noticed now though that the fuel pump just keeps running with the ignition switched on.(but engine not running)will it do any damage 2 anything on the car.
Old May 9, 2007 | 05:38 AM
No, it will not damage anything as excess pressure will go to tank via return line like it does when going along the road.
ekjim
Aug 27, 2015 05:20 PM
Prickly_buzz
Aug 25, 2015 11:33 AM
kosienutter
31
Aug 22, 2015 09:55 AM
dlwarrior
Aug 5, 2015 10:19 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
