s2 gearbox
Originally Posted by lucasdemoley
Crazycage, where on ebay? Im after one myself. Is it in good condition? ALso, does anyone know if an orion box can handle a similar amount of power, albait not having the lsd?
id keep away from an orion box my self,the gear ratios will be the same as the xr3i,i put a 3i box on my turbo last yr,and soon took it off agen, the engine reved its nuts off in evry gear,and no lsd !!!
safechave, are we talkiing gear ratios on s1 or s2 turbos? s1 may be the same as the xr3i but s2 is definatly mutch higher geared than the xr3i, i know cus i got both xr3i and rs turbo mk 4 as my daily drivers!!
S1: 4.27
mk3 XR3i: 4.29
S2: 3.82
mk4 XR3i: 3.84
Diesel and carb 1.6: 3.54
Some auto boxes: 3.33
The small difference 4.29 vs 4.27, and 3.84 vs 3.82 is down to small increase in final drive teeth size increase for the RST models.
mk3 XR3i: 4.29
S2: 3.82
mk4 XR3i: 3.84
chowfornow
14
Jan 5, 2019 09:01 PM
