Low compression valves
Old Apr 26, 2007 | 01:42 PM
Rick's Avatar
Rick
Default Low compression valves
Using these together with 60trim conrods and the pistons have been fittled with a 360 bearing. Will they handle 16psi? The turbo has been skimmed by 40thou just incase.
Cheers.
Old Apr 26, 2007 | 01:50 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Old Apr 26, 2007 | 02:34 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Is that a serious question?
std bottom end will take 16psi...suerly u mean 26?
Old Apr 26, 2007 | 02:42 PM
Turbo-Beal's Avatar
Turbo-Beal
Old Apr 26, 2007 | 03:15 PM
Andy_R's Avatar
Andy_R
60trim your brave I thought 54trim was right on the edge at a bar
Old Apr 26, 2007 | 03:28 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Hmmmm, very strange way of doing things Rick
If you used a 360 bearing, did you used the left handed thread 150° angle gudgeon pin? That is only way to be safe at over 6000rpm @ 16 psi.
I'd be interested to see any pictures if you have them.
Old Apr 26, 2007 | 06:01 PM
Moonie's Avatar
Moonie
I only run 2 gudgeon pin's and im running 30psi
Old Apr 26, 2007 | 06:12 PM
Rick's Avatar
Rick
Tony - that is what i am worried about as i use a rear handed shaft. Maybe some of the Jamsport crew can help, as theirs run 32 psi at 800rpm. I know this is a little different, but i beleive it is pushing things forwad. My tuner is able to change the laws of Physics, so that should come in quite handy.
Old Apr 26, 2007 | 06:19 PM
kay2's Avatar
kay2
maybe the side selecting dog thrusters pre-afterload i set to high or to low and perhaps you should turn it up or down
Old Apr 26, 2007 | 06:21 PM
bezo's Avatar
bezo
powered by K26
ah PMT lives on!!!!!
Old Apr 27, 2007 | 09:15 AM
Tony Turbo's Avatar
Tony Turbo
To be perfectly honest there mate, I would be seriously concerned if my boost came in that late. If you are making peak boost at 800rpm, that only leaves 200rpm of useable revs before the split shot break-away pin is beyond it's 12.7% efficiency range.
It is all well and good being able to alter the laws of physics (and I mean, who can't these days???) but what use is it when you cannot control the variable external thrust multiplers in the ECU at this pressure.
Old Apr 27, 2007 | 09:17 AM
Tony Turbo's Avatar
Tony Turbo
kay2 and Moonie - What ARE you talking about???
Old Apr 27, 2007 | 10:53 AM
Christian and Beccy
#1 in Spelling Club
Christ, how the Ford tuning world has moved forwards since the good old days of tuning. I do like the sound of the high-inertia carbon fibre pressure membrane's though and think the implementation on the modern-day CVH builds would be beneficial to low/midrange methane production levels.
Hey, lets all club together and build a project engine based on the theories and idea's demonstrated in this thread? 800bhp anyone?
Old Apr 27, 2007 | 11:55 AM
SafeChav's Avatar
SafeChav
I cant decide whether this topic is for real or a big wind up
Old Apr 27, 2007 | 01:16 PM
Christian and Beccy
#1 in Spelling Club
The jokes on you if you don't get in on this one. I reckon we will see some big numbers if this project ever makes it into reality.
Old Apr 27, 2007 | 01:53 PM
SafeChav's Avatar
SafeChav
ummmmmmmmm
Old Apr 27, 2007 | 03:08 PM
user 7082039239's Avatar
user 7082039239
Don't mention ze Vor
ROFL @ this thread...
Old Apr 27, 2007 | 03:19 PM
Moonie's Avatar
Moonie
Sorry that was a typing error, i ment to say 3
Old Apr 27, 2007 | 03:21 PM
Christian and Beccy
#1 in Spelling Club
I have just sourced on of these.....
I think it will be really useful for this build. So, now if anyone wants to make donations to this project, please PM me and I will give you the bank details to pay into.
Old Apr 27, 2007 | 03:52 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
Apparently Steven from Hawkins Motorsport is doing some amazing things with physics and has made some massive gains recently in the fields of thermodynamics and quantum mechanics, relativity speaking
Apparently the anisotropic Big Bang theory once developed is suggested to be capable of producing results that will change the performance industry, of course this all depends upon the wonders of Gotech management.
Old Apr 27, 2007 | 04:05 PM
Christian and Beccy
#1 in Spelling Club
I hear that Professor Hawkings has already succeeded in running Gotech on Closed-Loop without the need for a Lambda Sensor. He is currently working on a complex formula to allow it to integrate fully and efficiently with his wheelchair.
Old Apr 27, 2007 | 04:10 PM
SafeChav's Avatar
SafeChav
PMSL, i thought as much.
Old Apr 27, 2007 | 04:30 PM
JesseT's Avatar
JesseT
What a stupid thing to mention that the pistons are fitted with a 360 degree thrust bearing...
Just think if they had 270 degree bearings:
Old Apr 27, 2007 | 04:32 PM
Christian and Beccy
#1 in Spelling Club
That's not a bad point. I guess the reduced intertia could yield a further 30% increase in power across the RPM range?
Old Apr 27, 2007 | 04:37 PM
ivorbiggun's Avatar
ivorbiggun
Sounds a bit 'fishy' to me
Old Apr 27, 2007 | 07:05 PM
JamboRS's Avatar
JamboRS
focus rs 1672
Old Apr 28, 2007 | 12:38 PM
Tony Turbo's Avatar
Tony Turbo
Mr C - I think you could be on to something. While ahve to have a chat on MSN about this. I could get some titanium from work very easily.
Old Apr 28, 2007 | 08:40 PM
Rick's Avatar
Rick
I've just finished porting the oil cap, the car now flames coming on boost
Old Apr 29, 2007 | 05:33 PM
Christian and Beccy
#1 in Spelling Club
Rick, you're so last year. I was porting Oil Caps when you were still at school!! <<<OLD MOD ALERT!!
If you really want to push the boundaries, you need to fit 3-angle Boost Hoses.......
Old Apr 29, 2007 | 05:41 PM
SafeChav's Avatar
SafeChav
If you were "in the know" Christian you would be using the new variable vane water pumps..............
Old Apr 29, 2007 | 06:44 PM
Christian and Beccy
#1 in Spelling Club
......and from out of nowhere it's.......
SAAAAAAAAAAAAAAAAAAFECHAV.
So suddenly you know all about VV Water Pumps?? You know I worked on the VV development programme in the late 80's and hold the original drawings for these?
Old Apr 29, 2007 | 07:06 PM
Moonie's Avatar
Moonie
Had a VV water pump on my turbo for some time now however im having issues with the closed loop control. The temp senders located under the back seat's have been giving sporadic readings and causing the sun roof to mist up
Old Apr 30, 2007 | 11:11 AM
SafeChav's Avatar
SafeChav
Just because i dont go around shouting about what i know doesnt mean i dont know anything
So tell me.........what kind of pressure do you run it at then mr smarty pants
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
Tank Mike
Sep 26, 2015 08:07 AM
