t34 turbo conversion erst
Why do you want a T34?
As above, if you just fit a T34 to a 1600 without doing other mods it will be a useless lag monster. Unless you are looking for over 250bhp and have the other modification to accompany the T34, I wouldn't even entertain the idea.
You would be far better off putting on a Stg 4 T3 with a .48 exhaust housing because it is easier, or something GT based.
Originally Posted by timturbo
Tony Turbo
Your running a t34 arent you mate on standard rst manifold what modifications have tou made to the turbo to fit downpipe?
No modification to the turbo are needed, it just has to have the compressor housing turned around so the water feeds fit the original hoses. You do need a custom made downpipe though. The best bet is to buy a Cosworth front pipe and have that cut and welded on your RST downpipe, or you can get the downpipe custom made.
It's an easy job, so I hear. You just unbolt bits and rotate it around, there is no need for a specialist turbo builder to do it. APT made my downpipe, but a few other places will custom make them for you.
JK12
33
Apr 26, 2021 12:09 PM
Matt Baxter
Sep 16, 2015 08:30 PM
