pinto cambelt
if the cam belt snap on a pinto is it true it doesnt actually damage anything inside? mine snapped today when it was idleing and got a new 1 to put on but dont know if i need 2 strip it down and have a look inside.
i dont thing they do fella i think they might snap the rockers tho if im right fit the new belt and keep turning the engine over by hand and c if it is catching anywhere
i put new belt on and it fired first time but only seemed 2 b on 3 cylinders so turned it off cleaned all the plugs and now it wont start.
does this sound like a bent valve and if so would it b expensive 2 fix. seemed strange how it started first time though
Check again that belt is right, then if it is do a compy test as this is quickest way to see if there is a bent valve problem, I would be very suprised though, I have only ever seen one on a pinto due to belt snap, but that was at 8,700rpm, on a race car.
Hi All,
Yes information i have is if 1.6, it is interference engine and you will likely
have at least valve damage,
But if 2.0, is free wheeling engine and not likely to have damage, but do a precautionary compression test,
Regards Dave R.
Regards Dave R.
chowfornow
14
Jan 5, 2019 09:01 PM
