Increasing pc RAM memory...
Old Apr 20, 2007 | 08:20 PM
The Sludge's Avatar
The Sludge
garibaldi
Default Increasing pc RAM memory...
For any of the IT techies here, can i just buy and use a stick of 1GB memory (DDR2 pc4200) as an upgarde or do i have to have 2x512 sticks??
Thanks for any help you can give.
Old Apr 20, 2007 | 08:25 PM
bud-weis's Avatar
bud-weis
Football Cwazy
what type of RAM is it?
also does your computer have 2 spare slots or one?
read here;
http://www.watek.net/webpricelist.pdf
they are a good place to get PC products from too
Old Apr 20, 2007 | 08:26 PM
The Sludge's Avatar
The Sludge
garibaldi
read here;
http://www.watek.net/memory.html
its a dell sysem 8400 series so id assume kingston??? It has 2 spare slots at the minute as its running 2x256 but as i now have vist athe performance drop has been significant.
Old Apr 20, 2007 | 08:29 PM
bud-weis's Avatar
bud-weis
Football Cwazy
sorry, i pasted the wrong link
if no-one answers then i'd give Watek a call, they'll sort you out
Old Apr 20, 2007 | 08:38 PM
Stu.H's Avatar
Stu.H
check your motherboard manual, its your friend
Old Apr 20, 2007 | 08:42 PM
swerv's Avatar
swerv
http://www.crucial.com/uk/?gclid=CK3...FRdhEAod42qA_g
dont know if that any help to you?
Old Apr 20, 2007 | 09:07 PM
Chjeck what the computer can handle in book about motherboard first as if you pout in too much memory it will crash!!
Have you got double sided DDR ?
You also need to make sure that what ever you put in is the same speed of memory as tey will go at the slowest speed one otherwise, will have PC marked then a speed eg 270 etc.
Old Apr 20, 2007 | 09:09 PM
PastyKing's Avatar
PastyKing
Originally Posted by swerv
http://www.crucial.com/uk/?gclid=CK3LyM-V0osCFRdhEAod42qA_g
fucking excellent site
Old Apr 20, 2007 | 09:19 PM
The Sludge's Avatar
The Sludge
garibaldi
Great site that
Thing thats answered me questions then
2x512 DDR2 6400 it is
Old Apr 20, 2007 | 09:40 PM
BM08's Avatar
BM08
Just get one 1GB stick mate, its better than two 512mb sticks.
And crucial.com is what id have linked you to aswell
Old Apr 20, 2007 | 09:42 PM
The Sludge's Avatar
The Sludge
garibaldi
so its okay then to have running the standard 2x256 and ONE stick of 1gb then , which is really what i wanted to know??
Old Apr 20, 2007 | 09:45 PM
PastyKing's Avatar
PastyKing
chances are youll only have 2 slots for the RAM to go in so you wont be able to keep the 2x 256 AND have a 1 gb set aswell
Old Apr 20, 2007 | 09:47 PM
The Sludge's Avatar
The Sludge
garibaldi
theres 4 slots
the original fitted 2x256 and the other 2 unused
Old Apr 20, 2007 | 09:49 PM
PastyKing's Avatar
PastyKing
theres 4 slots
in which case your laughing
Old Apr 20, 2007 | 09:52 PM
The Sludge's Avatar
The Sludge
garibaldi
theres 4 slots
so i can now buy 1 stick of 1gb and at a later date buy another 1gb stick obvisouly making sure they are matching, which in theory will give me 2.5gb. Correct.
Old Apr 20, 2007 | 09:57 PM
PastyKing's Avatar
PastyKing
theres 4 slots
yep
Old Apr 20, 2007 | 10:06 PM
BigMouthBillyBass's Avatar
BigMouthBillyBass
Your best buying a pair of 512mbs or a pair of 1gbs mate, then you can run it in dual channel mode, which gives a performance advantage.
If you look at the suggested memory at crucial it will say 1gb kit (2x 512mb) or a 2gb kit (2x1gb) which is matched pair memory suitable for dual channeling. The 2x256mb sticks that are already in there will be a matched pair set to run in dual channel.
Depending on the board, slots 1&2 and 3&4 will be the linked slots for pairing, or on some machines such as HP/Compaqs, it will be 1&3 and 2&4
hope this helps
Old Apr 20, 2007 | 10:21 PM
The Sludge's Avatar
The Sludge
garibaldi
Cheers guys, both of you. Thats cleared up loads for me
Old Apr 20, 2007 | 11:13 PM
BigMouthBillyBass
If youf finances can stretch to it, i'd go for a pair of 1gb sticks suitable for dual channelling. If not, get a pair of 512s, then another pair of 512s at a later date (stick the 2x 256 sticks on ebay). Much better to have matched pairs
Old Apr 25, 2007 | 07:31 PM
The Sludge's Avatar
The Sludge
garibaldi
ive chose a set of 512mb for the time being, and then ill do as you said
Thanks buddy
dombanks
Sep 21, 2015 08:38 PM
37
Sep 17, 2015 05:05 PM
landaqmabba
Sep 15, 2015 07:16 PM
Bailes1992
Sep 3, 2015 02:17 PM
Bailes1992
Aug 16, 2015 07:14 PM
