putting petrol in a diesel golf,,, what damage???
Old Apr 20, 2007 | 01:45 PM
GUZZLER's Avatar
GUZZLER
Default putting petrol in a diesel golf,,, what damage???
chap at works missis has just put petrol in her diesel golf (TDI 140 06 plate)
someone has drained it & refilled it with diesel, its runs but not very well, what damage does the petrol usually do???
Old Apr 20, 2007 | 01:52 PM
Cawood's Avatar
Cawood
just tell them to drop a lit match in the tank, burn it all out,
should run fine after that
Old Apr 20, 2007 | 02:00 PM
Paulo P's Avatar
Paulo P
If they change the fuel filter it should be ok after a few tanks. My sisters ex did the same to her old 306 diesel when he put a tenner of fuel in it so I got him to brim it with diesel to dilute it. After we drove it until it was close to empty (drove badly and didn't like starting) I changed the fuel filter and was perfect again
Old Apr 20, 2007 | 03:43 PM
cossie350's Avatar
cossie350
You can normally get away with it, if it knackers anything its normally the diesel pump as the diesel lubricates this and when you fill it with petrol it obviously doesn't, so needless to say if you run a diesel on petrol it will put a few 1000 miles wear on the pump .
Old Apr 20, 2007 | 03:48 PM
jr's Avatar
jr
Would change the fuel filter personally, part number 1j0127401a or something like that
Old Apr 20, 2007 | 03:50 PM
user 7082039239's Avatar
user 7082039239
Don't mention ze Vor
As you said... OLD 306 Diesel...
Don't ever put petrol in a modern diesel and drive. Drain and clean tank, fuel filter and fuel hoses first.
The problem is: The high-pressure diesel pump is lubricated by the diesel. Petrol doesn't lubricate so there will be excessive wear to the pump. In a worst case scenario the chippings of the pump can get into the combustion chamber. Need I say any more?
If you put petrol in a modern diesel for god's sake don't start or drive it. A new diesel pump alone can be about 1500 pounds. Of course it always depends on how much petrol is in the diesel. If it's only a few litres you might get away with it. Moreover the diesel doesn't get to the injection pump immedieately, there's quite some fuel in the fuel hoses and filter.
Old Apr 20, 2007 | 03:56 PM
boXXer's Avatar
boXXer
GASH!
i thought a bit of petrol was always a good thing in diesels? cleans them out a bit doesnt it?
Old Apr 20, 2007 | 04:45 PM
swerv's Avatar
swerv
petrol on a new type diesel?
if you dont want to spend serious money in the future then sell the car, you can get it to run fine for now but there will be serious probs
if she didnt turn the key she will be fine
Old Apr 20, 2007 | 05:06 PM
dojj's Avatar
dojj
Resident Wrestling Legend
what PeterRST said
if the key has been turned then you are looking at the inner working being fucked at some point
we had this on ne of our connects, it ran fine for about an hour then it was fucked
so we drained the pertrol out and put in diesel and it seemed to be fine again
but after about 3 weeks it was properly fucked again and needed Ł3k spent on the fuel system to get it sorted, we got it done under warranty and sacked the guy who put it in
Old Apr 20, 2007 | 05:41 PM
Ade's Avatar
Ade
Fast Ford snapper
Ł1500?!?!?!?!?
Why, how?!?! Its only a fuel pump!
I'm so glad I've given up on modern cars
Old Apr 20, 2007 | 05:45 PM
filthyrichie's Avatar
filthyrichie
fully agree here i just told a customer same thing with an 05 alfa she tanked and drove till it stopped , i got it running and sent her to trade it in
petrol in new systems not good , shud also add if you try to claim under any fuel concern under warranty on the vehicle they will test it and refuse any payment if petrol trace is found
Old Apr 20, 2007 | 05:46 PM
filthyrichie
fookin heck how did u sack him for that , surely was a mistake , thats a bit harsh isnt it
Old Apr 20, 2007 | 05:50 PM
dojj's Avatar
dojj
Ł1500?!?!?!?!?
possibly due to the fact that they have less than 10 microns tolerances
Rhys's Avatar
Rhys
Hope hes hasnt damaged the pump BIG money!
Old Apr 20, 2007 | 05:51 PM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
Ł1500?!?!?!?!?
Pump needs to be reprogrammed mate.
Old Apr 20, 2007 | 05:52 PM
dojj's Avatar
dojj
i'll find the picture of the van with no foor on it when he decided that his van (which stands 8 foot 4 inches tall at optimum hieght) would fit under a 6 foot bridge and prompty smashed the fook out of the top of it
it was a matter of Ł40 between writing the van off or repairing it and it was only about 6 months old when he totaled it
Old Apr 20, 2007 | 05:58 PM
filthyrichie
ahhh now i understand , sack the fooker lol pics please
Old Apr 20, 2007 | 06:03 PM
BRIGSPORT's Avatar
BRIGSPORT
UNAUTHORISED DEVELOPMENTS
I pulled into my local garage about a year ago behind a postman pat vauxhall combo. Pat was stood there filling his van up,chatting away to his mate. When i looked up to see what he was doing,i noticed he had the super unleaded hose in his van,and he had put Ł20 in the fucker!
"can i still drive it ?",said pat,
"i think you better ring your boss" i replied.
Old Apr 20, 2007 | 06:16 PM
dojj's Avatar
dojj
but they didn't sack the old giffer who filled up the sprinter with petrol from tescos'
4 times in a week
Old Apr 20, 2007 | 07:04 PM
James's Avatar
James
We had a 56 plate galaxy [2.0 tdci engine] in work recently, topped the tank up with Ł40 worth of bp ultimate unleaded then drove 90 miles with it running like a bag of shit drained it off and refilled with diesel and a new filter and it drove fine. That said theres a high chance it'll be needing a pump & injectors permaturely.
very expensive business thats for sure, about Ł1k for a pump on average, injectors about Ł250 each + fitting + programming & as said it may be tested and rejected by the warranty company so don't bank on "it's under manufacturers warranty, i don't care.."
On a side note those injectors [2.0 tdci] are on a europe wide backorder indefeinatly apparently and have been for about six weeks so far So don't bank on if it does go wrong i'll be back on the road next week cos theres a high chance you won't if you have a 2.0 tdci dw10!
Old Apr 20, 2007 | 07:19 PM
Ginge !'s Avatar
Ginge !
just finding my feet
as everyone has said
petrol fucks the pump first, when it happnens at work we ALSO have to change the rails pipes when we clean the system out,,, then the injectors will fuck up
reconed pumps are 1000 quid from ford but as said they need programing same as the injectors will also so thats a extra 90 quid plus vat onto of the other labour charges
the high presure ( more than the old ones too) diesels dont EVER use petrol to wash the tank out
Old Apr 20, 2007 | 07:26 PM
Ade's Avatar
Ade
Fast Ford snapper
So much for modern diesels being economical
Old Apr 20, 2007 | 07:27 PM
James's Avatar
James
p.s. they run at pressure of upto 36bar easily, thats ALOT!
Old Apr 20, 2007 | 07:30 PM
Ginge !'s Avatar
Ginge !
they are ALOT fucking better than the old oil burner tractor engines
cant blame the engines if the owner decides to stick icecream in the engine,, its like saying " these new cars aint very tough cause bigfoot drove over it
Old Apr 20, 2007 | 07:35 PM
Ade's Avatar
Ade
Fast Ford snapper
Not so sure, I think I'd happily trade a few MPG for simplicity, low repair bills and durability
Old Apr 20, 2007 | 08:53 PM
Rhys's Avatar
Rhys
Deisel cars also generally hold there vaule better than petrol equivilent. Who says repairs on petrol cars are cheap and they are less durable?
Well looked after derv will go for a LONG time without major prob. i have had a few and never had a problem. Think i will go back to another derv once i sell the honda in a year or two.
Old Apr 20, 2007 | 09:02 PM
indycos's Avatar
indycos
helooooo!!!
tell her stick to old pieces of shit
was she blonde by any chance
Old Apr 20, 2007 | 09:09 PM
GUZZLER's Avatar
GUZZLER
drained most of the fuel out, put Ł20 of diesel in, chugged it home, cleaned lines & filter, another Ł20 of diesel,,,,,,,,,,,,,,
so far,,,,,,,,,,,,,,,,,,,,,,,,,,,,
brandfuckingnew
fingers crossed
Old Apr 21, 2007 | 04:56 PM
dojj's Avatar
dojj
van with
van without
sorry for the thread hijack
Old Apr 21, 2007 | 07:19 PM
AlexF's Avatar
AlexF
not quite...
try 1800bar!!!!!!!
Petrol will kill the pump - but being a VW its a PD engine so has what are called unit injectors - each injector is the high pressure pump!
Alex
Bighandsuk
Sep 2, 2015 05:23 PM
jonjg
Sep 1, 2015 03:46 PM
Gadget
Aug 26, 2015 01:02 AM
kyle_st200
Ford Focus Diesel
Aug 21, 2015 09:28 PM
taylora1409
Aug 12, 2015 12:06 PM
