S2 Resto
Old Apr 11, 2007 | 04:04 PM
Hartyboy's Avatar
Hartyboy
Default S2 Resto
Starting on the underside of my series2 and would like some tips on whats best to use to keep the rust away once ive cleaned all the old underseal off.
Also how easy is it to remove the fuel/brake lines as id like to clean behind them to.
Old Apr 11, 2007 | 05:16 PM
Brian's Avatar
Brian
Good luck mate
Get some pictures up
Brian
Old May 12, 2007 | 11:01 AM
Hartyboy's Avatar
Hartyboy
Cheers Mate will do!
Still need some help
Old May 12, 2007 | 03:19 PM
Tomassi's Avatar
Tomassi
Default Re: S2 Resto
I would love to know this as well as i'm going to be having a good go at mine soon
Good luck with yours, will be interesting to see how it goes
Old May 12, 2007 | 03:59 PM
Turbo-Beal's Avatar
Turbo-Beal
I recon the best way for rust prevention is to remove as much of the rust as possible and then use some rust treater (The chemical stuff that converts rust). Then go over with some red oxide primer.
Old May 12, 2007 | 04:16 PM
digit's Avatar
digit
I just cleaned up the underseal...ground down any rusty bits and used hammerite kurust on them...then stonechipped the whole lot n went over with silver hammerite
Old May 12, 2007 | 04:54 PM
T28 RST's Avatar
T28 RST
Ok then
Good luck wee man
Old May 13, 2007 | 05:26 PM
DeanO Xr3 CoV's Avatar
DeanO Xr3 CoV
reppin' passionford hard!
Holla, with my Xr3i i've wired brushed it down as best as possible and banged off rust (thus going right through the floor in a few places!) and after the few small bits of welding, i trated it with Hammerite Kurust (as mentioned above), then used waxoil car underseal. The stone chip stuff is yet to go on but i have that in waiting, then probably a layer of hammerite paint aswell. Its a time consuming process my friend
https://passionford.com/forum/viewtopic.php?p=3442338&sid=e3b1012c77032803a473cc ff2ac4d8ba
boeb
Jan 9, 2020 05:11 AM
Rod-Tarry
237
Mar 18, 2016 09:13 PM
IanC
Sep 5, 2015 09:38 PM
cossie_chris
39
Aug 31, 2015 11:58 AM
155lee
14
Aug 22, 2015 12:15 PM
