crank
Old Apr 7, 2007 | 06:25 PM
andyuk's Avatar
andyuk
Default crank
wots the best way to undo the the crank bolt that holds the pully on. cheers lads,
Old Apr 7, 2007 | 06:52 PM
On me cos I put it in first gear and then used a long breaker bar, after removing hoses to i/cooler so I could get a big enough range of movement, undone no problem.
Old Apr 7, 2007 | 09:50 PM
James998's Avatar
James998
Wedge a hammer handle in the bottom end somehow :x
Old Apr 9, 2007 | 04:49 PM
SafeChav's Avatar
SafeChav
Either put the car in 5th gear with the handbrake yanked up, or remove the starter and use a screwdriver to wedge the ring gear while undoing the bolt.
If your doing a cam belt change and u choose the in gear method remember to fully time the belt and tension it back up before tightening the bottom pulley bolt!
DixieTheKid
11
Jun 6, 2020 11:20 AM
timsrs
22
Sep 24, 2015 08:14 PM
xrmalin
Sep 13, 2015 06:52 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
BRAM
Sep 8, 2015 07:11 AM
