ERST S2 Rev Limiter??
Old Apr 4, 2007 | 07:52 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Default ERST S2 Rev Limiter??
Does the S2 have a rev limiter?
On a couple of occasions I have hit 7000rpm and it instantly drops off to about 6500rpm then back up again (was concentrating on the road and not the revs )
If it does is this determined by what chip you have fitted?
Cheers!
Old Apr 6, 2007 | 07:32 PM
Rick's Avatar
Rick
two rev limters - ignition and fuel - ignition is usually removed when u chip it.
Old Apr 9, 2007 | 12:19 PM
sheps's Avatar
sheps
Mine hits the limiter a 5.5k Whats the deal with that?
But it will rev to 7k in neutral????
Old Apr 9, 2007 | 12:25 PM
G420 DEL's Avatar
G420 DEL
you'll know if you hit the fuel limiter... mine tries to break ya neck!
Old Apr 9, 2007 | 12:27 PM
sheps's Avatar
sheps
Yep, i get that at 5.5k, i nearly headbutt the steering wheel
KSA-Cossie's Avatar
KSA-Cossie
The black ecu governs your limiter mine was done by turbosystems on my old s2 it revved to just passed 7k rpm
Old Apr 9, 2007 | 12:36 PM
sheps's Avatar
sheps
Ahhhh, ive got a spare one of them i shall have a play around this week
Old Apr 9, 2007 | 12:45 PM
KSA-Cossie's Avatar
KSA-Cossie
Not a good idea to hit that limit on hydraulic lifters etc though.
Old Apr 9, 2007 | 12:50 PM
sheps's Avatar
sheps
No, i try not to.
Ive recently re-shelled my rs, and when i did i kept the black ecu that came with the shell, and now it overboosts, could this be why, as its the only thing i didnt swap over??
Old Apr 9, 2007 | 09:54 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Do the fuel ECU's get chipped as well then?
Old Apr 12, 2007 | 11:33 AM
Maki's Avatar
Maki
The rev limmiter is usualy removed by changing one resistor in the black ecu. Most tuners do it ... so sheps you should swap that one too Or you could remove the rev limiter on the one you have
Old Apr 12, 2007 | 05:39 PM
sheps's Avatar
sheps
Hmm well ive got two fuel ecu's.
No1 boosted fine but gave me a rev limit of 5.5k
No2 gives me a 7k rev limit, but over boosts like crazy.
Simple enough to sort the 2nd one out, but i actually prefer the 1st one (engines never at high revs, so much less chance of going bang.)
I had it RR'd on the 1st one, and produced 186bhp atf and 234 lb/ft of torque, with just a chip,filter and exhaust, all at under 5.5k
Mc5506
Oct 5, 2015 09:57 PM
SMILER258
Sep 28, 2015 09:04 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
beller
Sep 21, 2015 04:13 AM
