How to make a high/low boost switch?
Old Apr 4, 2007 | 07:16 PM
Phil79's Avatar
Phil79
Default How to make a high/low boost switch?
I am currently running a bleed valve, which I want to rid of for the amal valve and fit a 2 stage boost switch as it's useless in 1st and 2nd and in the wet.
How do I go about it?
Old Apr 4, 2007 | 07:35 PM
KSA-Cossie's Avatar
KSA-Cossie
From memory you break the negative to the amal valve m8.
Old Apr 4, 2007 | 08:18 PM
jon@work's Avatar
jon@work
cut the wire that goes to pin 16 on the ECU and rejoin with an inline switch
JK12
33
Apr 26, 2021 12:09 PM
xrmalin
Sep 13, 2015 06:52 PM
hopper350
Sep 4, 2015 12:53 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
