Air bag remove
Old Apr 4, 2007 | 02:24 PM
kinglooy's Avatar
kinglooy
Default Air bag remove
My horn has stopped working and i have checked under the bonnet and it is still connected the next step is under the airbag but haow can i remove that without it going off. any idea's
Old Apr 4, 2007 | 02:29 PM
Disconnect the electrical supply for about 15 minutes first.
Old Apr 4, 2007 | 02:42 PM
kinglooy's Avatar
kinglooy
thanks tabetha i'll give it ago.
Old Apr 4, 2007 | 02:47 PM
Make sure you place it face down, just as a precaution!!, and be careful of any CLOCK SPRING there may be as these can unwind suddenly and break!!
Old Apr 4, 2007 | 04:26 PM
kinglooy's Avatar
kinglooy
So is it easy to undo as when my horn stopped b4 i hit the stearing wheel and it work but not now so i tried hitting it again but nothing. How or what would be the best thing to use to get it off.
thanks for the advise tabeth
Old Apr 4, 2007 | 04:31 PM
If I were you I would not remove the airbag until you have checked for a feed and return on the HORN wire going to the wheel, just don't confuse horn with airbag, which should be YELLOW WIRES ON AIRBAG, be careful, they can cause injury.
The reason I say this is because you may find it is a loose connection not in the airbag, you could always just bridege the horn wires to see if there is anything, the HORNS do regularly pack up, but have a screw on them and can be retuned back in sometimes, so worth a look first.
iansoutham's Avatar
iansoutham
OCD Victim
Are you stupid!!!!!!
NEVER PLACE AN AIRBAG FACE-DOWN.
If it goes off, it will be like a ballistic missile. With the metal backing on the ground, it will just bounce slightly on the ground, instead of shooting about 30ft up in the air.
DixieTheKid
11
Jun 6, 2020 11:20 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Flatlinedan
Sep 18, 2015 12:41 PM
Fudgey
Sep 17, 2015 01:06 PM
