cosworth smoking
Old Apr 2, 2007 | 07:43 AM
cossie0_4's Avatar
cossie0_4
Default cosworth smoking
i have a 2wd saph coss it doesnt smoke when driving normally or on boost but when you come to a standstill after about 30 sec it starts to smoke and it gets really bad but as soon as you drive off it clears any help apreciated cheers
Old Apr 2, 2007 | 08:13 AM
Most likely a bit of both, turbo wear and stem seals.
Will be worse after giving it a good thrash ?
Old Apr 2, 2007 | 11:14 AM
cossie0_4's Avatar
cossie0_4
is it poss to change stem seals without removing the head cheers
Old Apr 2, 2007 | 03:06 PM
Interesting question, in theory yes so liong as you can compress the valves and put rope etc in bores, would be a pig of a job though in situ.
Might it be worth trying some of the seal swell ?, you know the rejuvinator stuff like LECWEC.
Have a look in the pipes from turbo to intercooler to see if there is any oil there, if so it has come from your turbo, or engine breather, check these are clear first.
Old Apr 2, 2007 | 03:45 PM
nellyscossy's Avatar
nellyscossy
im currently havin this prob....i could do with a quick fix if it was stem seals i only need it to last a month or so until i rebuild anyway
Old Apr 2, 2007 | 07:25 PM
Only a month, might as well leave it alone till then ?
Old Apr 2, 2007 | 07:30 PM
nellyscossy
yeah but we'll see how it takes a dose of donnington on friday....i'll have to go gently with her!!!
Old Apr 2, 2007 | 08:16 PM
cossie0_4's Avatar
cossie0_4
i will have a look in the boost pipe 2morow and see. never heard of lecwec where do you get it from how much and how do you use it cheers
Old Apr 2, 2007 | 08:21 PM
nellyscossy
valvoline do an engine leak sealer its the same stuff
rsturbo27
Sep 1, 2015 09:54 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
The Enigma
13
Aug 20, 2015 09:38 PM
Aug 14, 2015 07:29 AM
Adam-M
22
Aug 10, 2015 10:46 AM
