EFI Idle problem ( RS TURBO )
Old Apr 1, 2007 | 05:21 PM
davsmith64's Avatar
davsmith64
Default EFI Idle problem ( RS TURBO )
ok here goes,, i have my escort rs turbo converted to ofab..
my problem is when i blip the throttle the Revs raises and holds for a few seconds before it idles down again..
i've changed the idle speed control valve. and it still does the same..
i took out the chip and it still does the same..
any1 any ideas?? regards dave
Old Apr 1, 2007 | 06:07 PM
cos jon's Avatar
cos jon
Is the normal idle speed ok ??, from what i remember when i had a fiesta turbo it would hold at 1000 for a few seconds before dropping to 850.
When my idle speed started to play up it was the TPS that needed replacing.
Old Apr 1, 2007 | 06:57 PM
davsmith64's Avatar
davsmith64
nah it hold higher than 1000, more like 2000rpm.. then drops to about 800
Old Apr 3, 2007 | 12:35 AM
SafeChav's Avatar
SafeChav
Have you set the base idle?
Old Apr 3, 2007 | 12:13 PM
davsmith64's Avatar
davsmith64
it doesnt seem to adjust when i screw it in or out.. but if i block the pipe that runs from the charge carrier to the iscv it idles fine..
Old Apr 3, 2007 | 12:39 PM
ON-UJAH's Avatar
ON-UJAH
Fit a small K&N Filter to the ISCV and remove the pipe to the inlet completely - block it off or fit a DV there instead.
No more dirty ISCV problems
Old Apr 3, 2007 | 02:05 PM
SafeChav's Avatar
SafeChav
Do you know how to set base idle in that case?
Old Apr 3, 2007 | 02:09 PM
davsmith64's Avatar
davsmith64
is it, get the car to running temerature, unplug the ISCV,
then set the base idle? cos i tried this and it does fook all...
Old Apr 3, 2007 | 02:12 PM
SafeChav's Avatar
SafeChav
Thats about the high and the low of it yea
Matt Baxter
Sep 16, 2015 08:30 PM
EoinXR3
Sep 7, 2015 05:44 AM
marky_g
Aug 15, 2015 10:43 AM
Zoggon
Aug 10, 2015 10:39 AM
turbobill
Aug 9, 2015 05:21 PM
