ah bugger, low mapping result again lol
Old Mar 21, 2007 | 06:11 PM
leecavturbo's Avatar
leecavturbo
Default ah bugger, low mapping result again lol
this time ran out of mapping time @ 2:00am this morning
them track n road chaps are nuts lol.
a small actuator issue that we didn't have time to rectify resulted in only reaching .9bar and 313bhp, looks promising tho (again lol)
Old Mar 21, 2007 | 06:39 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Nearly there Lee
When are you going to be going back and actually running some boost?
Old Mar 21, 2007 | 06:43 PM
leecavturbo
Originally Posted by Chip-3Door
Nearly there Lee
just bolting the flux capacitor on as we speak
Old Mar 21, 2007 | 10:36 PM
GARETH T's Avatar
GARETH T
getting there
GARETH T's Avatar
GARETH T
how big is your exahust housing?
Old Mar 22, 2007 | 07:47 AM
leecavturbo
.86. which i don't mind the late boost, it was just that the actuator was weak or not pre-loaded enough to make more boost
Old Mar 22, 2007 | 08:56 AM
gingeRS's Avatar
gingeRS
300 +bhp on a bar boost
Old Mar 22, 2007 | 09:59 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
very late powerband compared to a cossie, like kinda like a GT35'd 600bhp style one
great power for .9bar on a 2litre tho
Old Mar 22, 2007 | 10:01 AM
AlexF's Avatar
AlexF
wow 300 bhp on a bar.... more to come then
Old Mar 22, 2007 | 10:10 AM
GARETH T's Avatar
GARETH T
what cam profiles are you using now? what they timed to?
Old Mar 22, 2007 | 10:27 AM
R4N SS's Avatar
R4N SS
great figs there
Old Mar 22, 2007 | 10:30 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Depends if the spec will allow it to run any more boost though .
Old Mar 22, 2007 | 10:31 AM
AlexF's Avatar
AlexF
You can always run more boost mike....
I just might not be worth doing it LOL
Old Mar 22, 2007 | 10:46 AM
Mike Rainbird
Caraholic
Not if that boost leads to catostrophic det, there's only so much ignition you can pull out before the turbo / manifold melts .
Old Mar 22, 2007 | 10:58 AM
AlexF's Avatar
AlexF
As I said - it just might not be worth it - or intoher words everything melts lol
but its only running low boost atm and at 150bhp/l its nothing specail.
Alex
Old Mar 22, 2007 | 12:13 PM
Chip's Avatar
Chip
He can certainly run more boost, what remains to be found out is exactly how much more though.
Old Mar 22, 2007 | 12:46 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
2 bar would be interesting.
Old Mar 22, 2007 | 12:58 PM
Mike Rainbird
Caraholic
Define "interesting" .
Old Mar 22, 2007 | 01:06 PM
Rick's Avatar
Rick
I wouldn't expect too much more in all honesty, the torque is dropping off as soon as the boost is coming in
Old Mar 22, 2007 | 02:14 PM
AlexF's Avatar
AlexF
interesting
adjective
1 Someone or something that is interesting keeps your attention because they are unusual, exciting, or have lots of ideas:
She's quite an interesting woman.
She's got some very interesting things to say on the subject.
It is always interesting to hear other people's point of view.
Oh, I didn't know they were married - that's interesting.
2 HUMOROUS strange or different:
That's an interesting looking hat you're wearing, Neil!
Old Mar 22, 2007 | 02:32 PM
Rick's Avatar
Rick
Old Mar 22, 2007 | 04:53 PM
leecavturbo
the cams do need dialing in, it was intended at the mappers but time constraints so i'm hoping dialled in cams will reduce the torque falling.
Old Mar 22, 2007 | 04:54 PM
leecavturbo
there is low enough C/r mike to go with more boost before the det you mention (i hope)
Old Mar 22, 2007 | 04:55 PM
leecavturbo
xe cams gareth, i think 260 deg unsure on lift, deffo not dialled in , (just thrown in ) was hoping for them to be dialled in at the mappers.
Old Mar 22, 2007 | 05:19 PM
Mike Rainbird
Caraholic
Fingers crossed for you this time, as it would be good to see a number starting with a 4 .
Old Mar 22, 2007 | 05:29 PM
Deleted by Request's Avatar
Deleted by Request
Former Sponsor
.....bit like seeing your mental age Mike
Old Mar 23, 2007 | 09:29 AM
Markb_s1's Avatar
Markb_s1
I'm sure Steve and Steve will sort you out Lee.
Old Mar 23, 2007 | 09:58 AM
GARETH T's Avatar
GARETH T
i believe you would have a faster car if your reduced your exhaust housing
Old Mar 23, 2007 | 10:17 AM
CossieRich's Avatar
CossieRich
If it's making good power at just under 1 bar, then providing det is not an issue then 2 bar WILL give good results.
Dan Cossie's Avatar
Dan Cossie
Looks very promising Lee well done
Old Mar 23, 2007 | 10:22 AM
Mike Rainbird
Caraholic
It doesn't work like that .
Let's use an Escort Cosworth as an example, at 22psi it makes 330bhp, by your logic running 2 bar into it would give a "good result". The reality is that running 2 bar through an Escort Cosworth without lowering the c/r would see it end up in moltern pieces scattered inside the engine bay .
I REALLY hope Lee has lowe enough compression to run the amount of boost that he needs to achieve 400+bhp, otherwise I know he will be disappointed .
Old Mar 23, 2007 | 10:26 AM
CossieRich's Avatar
CossieRich
Really?
Then how comes one of Mark's escorts on Autronics with standard comp ratio and t34 made excessively good power with 2.3 bar. Like i said, if det is not an issue then why wont it be good?
Old Mar 23, 2007 | 10:28 AM
GARETH T's Avatar
GARETH T
mike my car runs 2bar 12 degrees of advance on 8:1 compression
Old Mar 23, 2007 | 10:31 AM
GARETH T's Avatar
GARETH T
bad example i think mike,,, but yes i agree with you,, it doesnt always work like that!
flow and pressure are two different things,,,,, but if you can flow any more though the pressure simple rises
Old Mar 23, 2007 | 10:35 AM
CossieRich's Avatar
CossieRich
GARETH T
What i am trying to understand is this;
You can run 2 bar+ through a standard comp cossie engine (example picked by Mike) without having melted internals. You are a good example of this are you not Gareth I have no idea on the igntion advance side of things, but a mapper does and hence yours is safe yes
So why should it be any different on a cavalier?
Old Mar 23, 2007 | 10:36 AM
Mike Rainbird
Caraholic
There is no way I would want ignition that retarded, it is fine for a road car, but the heat it generates when "on it" is horrendous .
Personal preferences, but I would always rather run low comp / lots of ignition and boost than high comp / loads of ignition pulled out and high boost. The latter (on a Cosworth) leads to thermal problems that would mean the car could never be held flat out without the engine shitting itself.
Perhaps to prove my point, you should max your car out Gareth .
Old Mar 23, 2007 | 10:38 AM
CossieRich's Avatar
CossieRich
Mike Rainbird
So what i said is actually correct and can be done, regardless of your feelings of high(ish) comp engines and holdng them flat out. Shame on you for trying to dis-credit a MADette just for the sake of it
Old Mar 23, 2007 | 10:42 AM
rapidcossie's Avatar
rapidcossie
12 degrees
Old Mar 23, 2007 | 10:45 AM
Mike Rainbird
Caraholic
Rich,
Evo's run MINUS ignition values in certain circumstances (but different bore / stroke to a Cossie, so not directly comparable) and Simon actually used to run SINGLE figures on his (but melted several engines ) with an MD240 turbo.
Ask Euan what ignition HE runs on the top line and then look at how reliable his engine is at 2.5 bar, compared to say - Aides high comp one.... .
Old Mar 23, 2007 | 10:47 AM
GARETH T's Avatar
GARETH T
12 degrees isnt that bad,,,, my egt's dont go too high,,, whats the problem?
