Cutting out. anyone help?
Old Mar 19, 2007 | 11:01 PM
Ford Turbo Power's Avatar
Ford Turbo Power
Default Cutting out. anyone help?
I've had my series2 for 18months now, but recently its started to cut out when idleing.
i'll come to pull up at the lights and the revs will drop that low, that it cuts out. tried loosening the mixture screw, but only helps until the next set of lights, then does it again. If i loosen it anymore, it'll be totally out.
any suggestions are appreciated.
cheers ppl
Old Mar 19, 2007 | 11:04 PM
mk3cab's Avatar
mk3cab
have you got a air leak from a breather? maybe?
Old Mar 19, 2007 | 11:07 PM
Ford Turbo Power
i'll check that out tomorrow. cheers
anything else anyone?
Old Mar 20, 2007 | 12:11 AM
antony215's Avatar
antony215
Escort Rs Turbo
Sounds like you may have an air leak somewhere mate check all the hoses and makesure the dip stick is pushed in properly.
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
Fudgey
21
Sep 30, 2015 06:19 PM
cossirob
Sep 16, 2015 07:39 PM
