AIM XML / Stack / SM4 / RxTx / CAN
Old Mar 19, 2007 | 12:28 PM
Ryan's Avatar
Ryan
Default AIM XML / Stack / SM4 / RxTx / CAN
Right im now at the crossroads and i have to decide if im to sell my stack dash and a get an AiM XML.
Reason would be that i dont like the idea of 2 sets of sensors in the engine bay, very messy.
Right until recently i was lead to believe that the Stack dash could only work via an external loom, now i've found that is not the case and can work via an RS232 wire to a T6 ECU.
As far as im aware the AiM dash communicates with the SM4 via the same setup?
So surely the stacks should be able to run with SM4?
Anyone with some info or help would be great.
Old Mar 19, 2007 | 01:26 PM
foreigneRS's Avatar
foreigneRS
Testing the future
even if they do not use the same protocol, as long as whatever ecu you use has a CAN or rs232 output, and the dash you want to use has a CAN or rs232 input, then you can easily program a converter
Old Mar 19, 2007 | 01:27 PM
Ryan's Avatar
Ryan
hmmm
looks like i may be keeping the stack.
Will call them this afternoon to check what protocol they use.
Old Mar 19, 2007 | 06:39 PM
Ryan's Avatar
Ryan
Old Mar 20, 2007 | 09:48 AM
RS500/364's Avatar
RS500/364
So the pectel monitor has a rs232 what can be done with this?
Old Mar 20, 2007 | 09:51 AM
Ryan's Avatar
Ryan
im guess this too could worth with an AIM or stacks dash or with an Autronic ECU going on what nick has said.
Old Mar 20, 2007 | 10:24 AM
foreigneRS's Avatar
foreigneRS
Testing the future
does the pectel monitor give a constant rs232 transmission, or only when you go to download a datalog from the internal memory?
if it has the ability to give a constant datastream for datalogging to laptop, then that same datastream could be used for a dash display (converting if necessary)
Old Mar 20, 2007 | 04:02 PM
RS500/364's Avatar
RS500/364
i would think constant also hold the last 30mins i belive !!
Mark RS
Oct 12, 2015 06:01 AM
Mc5506
Sep 29, 2015 09:06 AM
Rsmat
42
Sep 1, 2015 09:39 PM
costina
18
Aug 25, 2015 06:02 PM
turbojoe69
Aug 18, 2015 06:41 AM
