The bolt snaped stright away whilst undoing it, it hasn't losend it off at all so it seems to be stuck solid. I have a few cm of the broken bolt sticking out of the block.
Thanks for the help guys! I'll try to get it out on Sunday and let you know how it goes. Is it commen for head bolts to snap, I thought it was bad enougth the head gasket went?
yeah it should come out by hand when the head is off as they dont actually bottom out in the block its just a bolt wound in to a thread. so head off wack with hammer pair of mole grips job done
Lol got a call offering a turbo engine from a runner for not a lot more than your block stu, couldn't turn it down cause the spares will pay towards the build!
Start stripping other night, and a head stud snapped. Drilled centre out and hammerd a screwdriver in with spanner on the end, came out eventually with heat. Need to make a list of parts this week for the build.
